Author Topic: 24" inch RED ( 1/0 AWG ) SAE Battery Cables SIZE : DIAMETER 1/0 GAUGE  (Read 4943 times)
February 27, 2010, 10:09:18 am
GEE-BEE
  • 1604
If you want more power from your battery for starting and you want to upgrade your cc size, a larger cable is the answer
Stock is 4 gauge, you should update to at least 1/0 gauge for the positive wire..
I have purchased box ( lot) of 24' battery cables for my upgrade 1/0 Gauge.
There is a ad for these in the For sale section.
Stock negative ground is a 6 ( wire size ), I installed a Size  2 wire /24' long
Gee-Bee
« Last Edit: February 27, 2010, 06:28:43 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1February 27, 2010, 10:17:20 am
Re: 24" inch RED 1/0 AWG SAE Battery Cables
« Reply #1 on: February 27, 2010, 10:17:20 am »
1/0   or 1 gauge???
I went with 1/0 and it is amazing, 1 gauge would be good, but almost 1/2 the size of 1/0 I think
Reply #2February 27, 2010, 01:39:13 pm
rallydiesel
  • 1880
Re: 24" inch RED ( 1/0 AWG ) SAE Battery Cables SIZE : DIAMETER 1/0 GAUGE
« Reply #2 on: February 27, 2010, 01:39:13 pm »
What size should the ground be?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3February 28, 2010, 11:15:01 am
1outof5
« Reply #3 on: February 28, 2010, 11:15:01 am »
in the "big 3" upgrades it's the engine/gearbox to ground, battery to ground and battery to alternator that can profit from a raise in size
I would also upgrade the live to starter motor
Reply #4February 28, 2010, 03:21:26 pm
GEE-BEE
  • 1604
« Reply #4 on: February 28, 2010, 03:21:26 pm »
Size 2 for the ground is what Iam installing to body from top post to ground
Another ground for the side post to body
Size two positive to main wiring harness from side post ( optima )
These are 1 / 0 battery cable top post to the Starter
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #5March 08, 2010, 10:26:41 am
VW Smokr
  • 114
« Reply #5 on: March 08, 2010, 10:26:41 am »
Same size as the positive cable... you're trying to ram the same amount of electrons through it.
Ditto on the BA positive cable direct to the starter solenoid's starter power terminal! Personal preference is also to use a (Canadian or US-made) Ford fenderwell starter solenoid relay in the ignition switch line to the VW starter-mounted solenoid. Reduces the load on the factory ignition switch, plus it provides a convenient attachment point for remote (momentary) starter switch leads, to bump the engine over to TDC, observe valvetrain action, etc.
J.R.
SoCal
Reply #6March 08, 2010, 11:08:21 am
GEE-BEE
  • 1604
« Reply #6 on: March 08, 2010, 11:08:21 am »
I did a Optima dual post type battery
Double ground wires top & side post on my MK caddy.
Wires are now four times larger than tock on both pos & neg.
GB
Giles Pump OHC
MK1 JETTA DASH
