Author Topic: Parts Order: 1.9 AAZ into rabbit AND parts supplier recommendation in the US??  (Read 2134 times)
February 24, 2010, 09:50:36 pm
purvisgs
  • 45
I have a 93 aaz with 5spd attached ready to go into an 80 pickup.
While it is out, I know I should probably put on a new timing belt... The engine I have already has a keyed crank pulley :)  Exhaust and intake and turbo still bolted to it.
I am planning to order:    !!I AM SURE I AM MISSING A FEW THINGS, ADVICE APPRECIATED!!!
Rabbit motor mounts
timing belt (and tensioner?)
oil filter
oil pan gasket
valve cover gasket
(or should I just get gasket set for the engine)
Also, who would you order it from I have called a few vw suppliers and they say "We do not carry parts for the AAZ it was Canada only"
Thank you!
Reply #1February 25, 2010, 12:07:46 am
rabbid79
  • 684
Yes, do the tensioner pulley too.  Perhaps pop-test the injectors?  Make sure to replace the heat shields if you decide to remove them.  Test and replace bad glow plugs too.  Order your parts through 1stvwparts.com.  They're a VW dealer in the PNW.  Excellent prices and service.  They can get all of your AAZ parts.
'15 WRX
Reply #2February 25, 2010, 06:50:59 am
GEE-BEE
  • 1604
Water pump 55.00 ( With new Housing ) German OEM
Hoses ( 3) 42.50
Clean the motor before install
If it was a gas you will need 1.6 coolant housings ( temp sensors )
Was it a four speed or 5 speed beforel
Autohausaz.com
Funny thing I have a brand new dash and cluster in the factory box
A 1980 will be my next build..
GB
« Last Edit: February 25, 2010, 07:19:06 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
