Author Topic: mk2 16'' tire size  (Read 9107 times)
February 22, 2010, 05:30:19 pm
hustonr123
  • 124
mk2 16'' tire size
« on: February 22, 2010, 05:30:19 pm »
I bought some rims that had 205/55/16 tires on them.    The tires didnt look to big untill I put them on my car. They rub hitting bumps and turning real sharp.  Was wondering if somebody can tell me what size fits good on a mk2 jetta at stock height.
Reply #1February 22, 2010, 07:50:15 pm
Re: mk2 16'' tire size
« Reply #1 on: February 22, 2010, 07:50:15 pm »
probably a 205/40/16 or a 205/45/16.
im running 205/40/17's on my car, and they rub too, but im lowered, so you shouldnt rub.
Reply #2February 23, 2010, 05:58:33 pm
hustonr123
  • 124
« Reply #2 on: February 23, 2010, 05:58:33 pm »
has anybody ran 205 50 16s on there car?  i found 4 cooper tires 25 bucks each and have around 8/32 tread left on them
Reply #3February 23, 2010, 06:20:22 pm
mystery3
  • 774
« Reply #3 on: February 23, 2010, 06:20:22 pm »
Use a tool like this:
http://www.miata.net/garage/tirecalc.html
Try to find a size close to stock?
Reply #4March 07, 2010, 05:31:34 pm
superleggera
  • 10
« Reply #4 on: March 07, 2010, 05:31:34 pm »
Hi, I ran 205/50/16 tyres and they rubbed on the front when trying to put full lock on the steering when parking etc and the rears rubbed when I cornered hard or hit a bump fast.
I've posted a thread asking if anyone knew if 205/45/16 was okay.....I think 205/40/15 is too small, you'd lose too much top speed and the ride would be terrible -the roads around where I live aren't great.
Reply #5March 15, 2010, 05:23:07 pm
superleggera
  • 10
« Reply #5 on: March 15, 2010, 05:23:07 pm »
I ended up fitting 195/45-16 on my 16" inch rims. Fits perfect and the gearing etc is virtually identical.
Reply #6March 24, 2010, 01:22:07 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #6 on: March 24, 2010, 01:22:07 am »
195/45/16 is good, so to is 205/45. any bigger is too big.
'91 Golf Cabrio 1.9TD
Reply #7March 27, 2010, 04:40:54 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #7 on: March 27, 2010, 04:40:54 pm »
Roll the fenders.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #8March 27, 2010, 10:02:32 pm
Runt
  • 83
« Reply #8 on: March 27, 2010, 10:02:32 pm »
Kudagra  : Roll the fenders.
Do you just roll the lip up, or do you deform the actual fender, that is try to force the fender out and/or up?  I am going to roll mine I think, and I was wondering if I could put enough force on them to force (bend) them outward a little, or if I would just screw them up.  I would be using a fender roller tool that bolts to the hub, and is adjustable for angle of the roller, and height and angle from the hub.
pics of the tool:
One DD 92 Jetta, One 91 Collision write-off, and One 92 rust free shell, beautiful, stripped, waiting for diesel-ization.
Reply #9March 29, 2010, 05:54:04 pm
Runt
  • 83
« Reply #9 on: March 29, 2010, 05:54:04 pm »
Also, do you guys find that you can deform the plastic flares when you roll them, or do you strip the plastic?  If you roll them without the flares, is there a way to reshape the platic so that I can put it back on afterwards?  I'm concerned that as the lip rulls up into the fenderwell, the flare will lift up and away from the fender on the outside.  Anyone have any experience with this?
Thanks
Reply #10March 29, 2010, 06:47:44 pm
mystery3
  • 774
« Reply #10 on: March 29, 2010, 06:47:44 pm »
That would referred to as pulling the fenders and I would not want to experiment with my own car. It shouldn't be too expensive to have a panel beater take care of it for you. If you do experiment with your car start on the front, at least the front fenders are bolt on!
Reply #11April 13, 2010, 07:57:39 pm
colhel59
  • 34
« Reply #11 on: April 13, 2010, 07:57:39 pm »
i have 205/45/16 i will be getting 205/40/16 next time i rub constanly with a 40/60 drop
