Author Topic: I know I know this is out of our comfort zone......  (Read 5723 times)
February 21, 2010, 11:58:06 pm
rabbitman
  • 2788
« on: February 21, 2010, 11:58:06 pm »
The car in question is a '00 Jetta 2.0L
We're trying to watch the Olympics and all is good but as soon as the relatives drive up in that car we get diagonal lines across the screen. They parked in different spots trying to fix it but to no avail.
The fix was to disconnect the battery and all was good again.......strangely enough the car also will kill the battery in 3-7 days :o. When he unhooked tha battery it also had a perdy good spark.
So I'm thinkin' something is transmitting a signal all the time which eventually kills the battery.
Any ideas on this? Thanks :)
(They have two of these cars and both kill battery's so I'm thinkin' it must be a common problem........)
Reply #1February 22, 2010, 01:01:51 am
Syncroincity
  • 727
Re: I know I know this is out of our comfort zone......
« Reply #1 on: February 22, 2010, 01:01:51 am »
Wow, that's a good one... Maybe a built-in garage door opener, what's it called, Home-link something like that? Do the cars have aftermarket stereos and/or amps? Bluetooth devices, GPS systems, etc. Eliminate all non-stock items first.
 Easiest thing to do is hook up an ammeter in line to the battery main and start pulling fuses one at a time until you find the current draw. It's not much if it takes days to kill the battery. That will tell you what circuit it is, then you can figure out what is stuck on.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #2February 22, 2010, 08:54:08 am
  • 3255
    • My collection of HOWTOs
« Reply #2 on: February 22, 2010, 08:54:08 am »
Good catch... that's exactly what it's called... and as far as I know that's the only radio transmitter in the car.... if so equipped.
My understanding is that it's powered by Fuse #5:
Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
Might be a quick first step is to yank that fuse and see if your squiggly lines go away... NOTHING is more important than the Olympics!!
Reply #3February 22, 2010, 11:15:35 am
rabbitman
  • 2788
« Reply #3 on: February 22, 2010, 11:15:35 am »
Wow that actually doesn't sound very hard.
Vince you say all that stuff is powered by the same fuse?
Thanks a lot I'll tell 'em ;D
Reply #4February 22, 2010, 12:12:20 pm
  • 3255
« Reply #4 on: February 22, 2010, 12:12:20 pm »
'Tis, and supposedly Homelink as well.
Reply #5February 22, 2010, 04:35:00 pm
  • 1739
« Reply #5 on: February 22, 2010, 04:35:00 pm »
Not sure what a home-link is? is it like on-star? Any-who i think it may have a Boomerang- other markets call it something else, but it's a GPS homing device to deter theft. I've seen lots of them cause battery drains ,plus they are always transmitting.
Reply #6February 22, 2010, 10:49:52 pm
rabbitman
  • 2788
« Reply #6 on: February 22, 2010, 10:49:52 pm »
Well, he pulled the #5 fuse today but at the same time turned the ipod transmitter off so I don't know what fixed it.........next time we'll try one at a time.
