Author Topic: Dakota Digital Diesel Tach Tachometer Adapter DSL-1 experience  (Read 2863 times)
February 20, 2010, 01:40:17 am
Familydiesel
  • 154
« on: February 20, 2010, 01:40:17 am »
Have any of you used the Dakota Digital Diesel Tach Tachometer Adapter DSL-1  with a gasser tach?  How did it work?  I have a 1980 Rabbit pickup and bought a nice year compatable tach/speedo setup from a scirroco (2 round holes for speedo and tach).  I am using a "w" terminal alternator to give the signal.  Does this converter work well?  I don't know that I want to play with changing the tach resistors if I can help it.  I would appreciate hearing any experiences with this kind of approach.   :-\
I have read some recent ideas about pickups, so would be open to soweone who has converted successfully to one of these approaches that is simple and the parts resonable and easy to find.
Thanks, :)
Greg
1980 Diesel td pickup, Love that Diesel!
Reply #1February 20, 2010, 07:46:51 am
Re: Dakota Digital Diesel Tach Tachometer Adapter DSL-1 experience
« Reply #1 on: February 20, 2010, 07:46:51 am »
its supposed to be a bolt on and go thing with the dakota digital converter box. just gotta adjust the pot on the box to get the tach to read right.
Reply #2February 20, 2010, 08:28:48 am
dokarex
  • 61
« Reply #2 on: February 20, 2010, 08:28:48 am »
I recently was in contact with DD and they said their converter will work with pre 86 VW tachs but not post 86 tachs because of the voltage the tachs call for. As long as you have a pre86 tach you should be good to go.
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #3February 20, 2010, 10:11:01 am
GEE-BEE
  • 1604
« Reply #3 on: February 20, 2010, 10:11:01 am »
WHAT ABOUT THIS KIT:www.4crawler.com/Diesel/CheapTricks/Tachometer
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
