Author Topic: Car fire. Please help.  (Read 6444 times)
November 16, 2005, 09:50:11 am
Z1K
  • 6
« on: November 16, 2005, 09:50:11 am »
I have a 92 NA diesel Jetta. The wiring caught fire. I was able to get it out and save the car but I now have numerous wires burned and fused together under the dash.
I'm just going to look for a parts car to buy to get the harness out of. What I need to know is what year range of cars can I get that it would be a direct swap? And is the wiring the same for the golf and jetta?
Thanks.
Reply #1November 16, 2005, 10:53:49 am
vwmike
  • 1158
Re: Car fire. Please help.
« Reply #1 on: November 16, 2005, 10:53:49 am »
90 and later cars were CE2 (Central Electric 2) so you'd need a 90-92 car. I would think the wiring would be the same in a gas car, but I'm not totally sure about that.
Reply #2November 16, 2005, 11:22:14 am
Z1K
  • 6
« Reply #2 on: November 16, 2005, 11:22:14 am »
What if I swapped the entire harness from front to back? Could I go with an earlier car then?
Thanks
Reply #3November 16, 2005, 01:15:18 pm
vwmike
  • 1158
« Reply #3 on: November 16, 2005, 01:15:18 pm »
probably....but that's way more work then just changing the affected wiring.
Reply #4November 16, 2005, 01:22:37 pm
BlackTieTD
  • 1512
« Reply #4 on: November 16, 2005, 01:22:37 pm »
vwmike: is there any clear indication of whether or not a 1990 car is CE2 or not? it may help this guy to be able to distinguish between the two... plus i have a '90 that i'm not too sure on. says central electric.... but nothing about a '2'.
Reply #5November 17, 2005, 02:21:45 am
vwmike
  • 1158
« Reply #5 on: November 17, 2005, 02:21:45 am »
As I understand it, Jettas were CE2 from mid '89.
Reply #6November 18, 2005, 06:46:52 pm
Z1K
  • 6
« Reply #6 on: November 18, 2005, 06:46:52 pm »
Quote from: "vwmike"
The problem is most of the wiring is affected. Pretty near everything behind the fusebox got affected in one way or another. After the fire I could get the car started up but that was about it.
Things affected:
Headlights were stuck on high beam
Front marker lights stuck on
No lights whatsoever in the rear
Hazards or signals wouldn't work.
Stereo wouldn't turn on.
Heater controls didn't work
Parking brake light always on
Ignition wires fused together so that when I turned the key off it was like I did nothing.
I figure it would just be easier to put in another complete harness than to sort that mess out.
Thanks for the help. You guys have any other ideas?
Reply #7November 18, 2005, 07:31:54 pm
vwmike
  • 1158
« Reply #7 on: November 18, 2005, 07:31:54 pm »
Well, that sucks...I guess just replace whatever you have to. You're kinda lucky though because if it was gas there would be more wires to replace  :)
Reply #8December 04, 2005, 12:10:45 pm
SMOKEYDUB
  • 630
« Reply #8 on: December 04, 2005, 12:10:45 pm »
I know for a fact that a gas harness is totally different. i had to chang my car over to diesel.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #9December 04, 2005, 12:50:10 pm
vwmike
  • 1158
« Reply #9 on: December 04, 2005, 12:50:10 pm »
Quote from: "SMOKEYDUB"
There are sections which are different but in a CE2 application the different harnesses ought to plug into the fuse box.
Reply #10January 03, 2006, 11:21:24 pm
Wingaman
  • 7363
    • http://www.dmfdiesel.com
« Reply #10 on: January 03, 2006, 11:21:24 pm »
Almost every wire from the gaz is the same of the diesel.
Only the harnes going to the ECU for the gaz is different, but you can use this wire and take the 2 first wire for the pump solenoid and the other one for the glowplug harness.
I didn't change any wire when i dropped a 1.9TD in my Jetta 90 1.88v. And ALL is working, including the tach (i put a tach from a jetta diesel on the harness of the gazzer).
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #11May 17, 2006, 10:13:12 pm
cleoo
  • 14
Will a 1982 Rabbit Gas wiring harness work in a 1982 Diesel?
« Reply #11 on: May 17, 2006, 10:13:12 pm »
The 82 Diesel's wiring harness shorted and burned, so is it better to try to wire it up with the rabbit gas harness since I can't find a diesel replacement.
Or should I remove the burned wiring and try to replace the burned wires???
1982 Volkswagen Rabbit Diesel 4 dr Burnished Metallic Gold 1.6NA
Reply #12May 18, 2006, 01:09:35 am
Re: Will a 1982 Rabbit Gas wiring harness work in a 1982 Die
« Reply #12 on: May 18, 2006, 01:09:35 am »
Quote from: cleoo
if you have enough room, just patch up the burnt wires and use some heat shrink.  if you cant, then find a wiring harness  (might be a good idea to switch to a thicker wire at this point as well...)
