Author Topic: Clutch Upgrade  (Read 2592 times)
February 18, 2010, 07:46:32 am
ryanp
  • 269
Clutch Upgrade
« on: February 18, 2010, 07:46:32 am »
I've fitted a blown 1y engine/box to my dad's mk1 caddy
what cheap/uprated clutch can i fit to hold with a mildly tuned engine?? the stock one now is slipping like a ***, either due to oil contamination or just wear (most probable as it's right at the top of the pedal!)
I'm running the Mk3 gearbox so i'm assuming i need the complete mk2 golf 16v setup?
I know i should have changed it whist the engine was out but that's too easy, lol!
Thanks!
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #1February 18, 2010, 08:04:48 am
Re: Clutch Upgrade
« Reply #1 on: February 18, 2010, 08:04:48 am »
being at the end of the pedal could just be a mis-adjusted clutch cable. but if its slipping, i would change it out no matter what. and yea, an aba or 16v clutch kit will work just fine.
Reply #2February 18, 2010, 08:17:16 am
Re: Clutch Upgrade
« Reply #2 on: February 18, 2010, 08:17:16 am »
Stock should be able to handle a 1Y
Reply #3February 18, 2010, 02:17:42 pm
ryanp
  • 269
Re: Clutch Upgrade
« Reply #3 on: February 18, 2010, 02:17:42 pm »
it's got a turbo too :) i might as well upgrade a little to make it worthwhile.
the clutch cable adjustment cant make the pedal any better.
I'll check a UK forum to see what those guy's fit
Reply #4February 27, 2010, 04:03:33 pm
ryanp
  • 269
Re: Clutch Upgrade
« Reply #4 on: February 27, 2010, 04:03:33 pm »
can anyone confirm that i want a 16v mk2 clutch?
Thanks!
Ryan
Reply #5February 28, 2010, 08:17:15 am
Re: Clutch Upgrade
« Reply #5 on: February 28, 2010, 08:17:15 am »
if you have a standard 020 trans (small 24 spline input shaft) and you want an uprated stock clutch, then you need an 8v clutch disk and 16v pressure plate. if you have a large spline 16v/mk3 020, then you can just use a straight 16v clutch setup.
Reply #6March 02, 2010, 12:48:29 am
ryanp
  • 269
Re: Clutch Upgrade
« Reply #6 on: March 02, 2010, 12:48:29 am »
i cant remeber which size splines the gearbox has! i'll have to ring around.
ta
Reply #7March 02, 2010, 07:08:19 pm
  • 2932
Re: Clutch Upgrade
« Reply #7 on: March 02, 2010, 07:08:19 pm »
If you know the code, you can look it up.
