Author Topic: questions on internals  (Read 2279 times)
February 16, 2010, 05:09:30 pm
L1V3N 1T
  • 13
« on: February 16, 2010, 05:09:30 pm »
i have a 90 td that is my DD i have a parts engine from a 91 straight diesel does every thing match up spec wise for the heads and block. I finaly got some head studs so i want to rebuild the head of the 91 and take a sunday to tear down and get it back to gether for monday.
Thanks
Reply #1February 16, 2010, 05:46:29 pm
Dakotakid
  • 1240
Re: questions on internals
« Reply #1 on: February 16, 2010, 05:46:29 pm »
So, apparently, your question is whether or not you can safely interchange a hydraulic N/A head with a hydraulic TD head....and whether or not the N/A head is adequately alloyed to survive the heat?
This topic was kicked around recently and I think Libby was wanting a definitive answer for it.
All I can say is that when I purchased a rebuilt head from (the "other" forum) Jack in Ohio over a year ago, Jack stated that there was "NO DIFFERENCE" in the "D" and "T" heads and that he could accept the standard (commonly supplied from the factory) "D" head (N/A supplied) to rebuild and then safely supply for a turbo application.
Furthermore, these hydro heads require the more expensive TRW valves (sodiums?) for rebuild.
However, this does NOT hold true for mechanical heads.
Anyone with an opposing view?
Reply #2February 17, 2010, 09:01:34 am
« Reply #2 on: February 17, 2010, 09:01:34 am »
i would use whatever head i had to use to get the sodium valves. but i thought they only came in factory turbo engines?
of course you could buy them aftermarket and put them in whatever head you want.
Reply #3February 18, 2010, 05:18:56 pm
L1V3N 1T
  • 13
« Reply #3 on: February 18, 2010, 05:18:56 pm »
So i called up the dealer this morning and you are correct they changed the exhaust valves on the turbo, the intakes are the same. I found the intakes for $12 each but i am having an issue finding the exhuast ones through the parts places my work can get good deals through. the stupid VW dealer want $40 a piece. Now the next question does any one know if there is any thing different in the bottum end?
Reply #4February 18, 2010, 05:58:32 pm
Dakotakid
  • 1240
« Reply #4 on: February 18, 2010, 05:58:32 pm »
Turbo engine uses oil squirting (piston) nozzles and the turbo crankshaft is drilled slightly different on the crank weights.
Reply #5February 19, 2010, 03:07:33 pm
L1V3N 1T
  • 13
« Reply #5 on: February 19, 2010, 03:07:33 pm »
ok well thats crappy i can't use much on this parts engine. thanks for all the info tho save me from finding out the hard way!!
Reply #6February 19, 2010, 05:30:03 pm
« Reply #6 on: February 19, 2010, 05:30:03 pm »
Air cooled engines plus has full stainless valves for less than what oem sodium filled are. He is in Tiffin ohio. See my build thread for anymore info.
