Author Topic: 11mm Electric pump wiring. Early 2 piece plug to later single piece connector  (Read 7357 times)
February 16, 2010, 11:48:20 am
superspringer
  • 42
Howdy y'all.
Ive not got access to my project car at the moment so can't simply go to the bonnet and check but in short here is my question:
I have ebay sourced an 0460 414 987 11mm pump (038 130 107 J) from an auto ALH engine. I am planning on installing it on my 1Z (along with the hybrid turbo, AFN injectors, large FMIC etc etc) in my MK2 Golf GTi. The pump is in my house and the car is locked in a friends garage who is away.
I know it isn't the preferred method of choice of most on the forum, but I have taken the fairly lengthy steps to keep the electrics (installed the fly by wire throttle, full wiring loom, ECU etc) and so far it has been fairly plain sailing. However the ALH 11mm pump has a 10 pin wiring plug and the 1z only has 8. (But from looking at various web pictures it would appear that there is a second 2 wire plug that comes from the earlier pump).
In short, is there anyone who has bolt off --> bolt on experience of the later pumps to the earlier engine? Can I separate the 10 wires into 8 and 2 to connect to the 1Z loom?
The wiring on the car up till now has been simply a matter of cutting off the required plugs from the mk3 tdi loom and soldering on the relevant plug/socket from the mk2 GTi one to correspond to the motor/switch/bulb etc that it is connectong to.
« Last Edit: February 18, 2010, 05:59:03 am by burn_your_money »
Reply #1February 16, 2010, 07:46:59 pm
Re: 11mm Electric pump wiring.
« Reply #1 on: February 16, 2010, 07:46:59 pm »
Yes but you will be missing a ground (I think) Actually I think you'll have an extra... it's possible though
Reply #2February 17, 2010, 05:12:33 am
« Reply #2 on: February 17, 2010, 05:12:33 am »
one make mix your pomps ca will go more quickly
Reply #3February 17, 2010, 01:14:32 pm
ChopSauce
  • 514
« Reply #3 on: February 17, 2010, 01:14:32 pm »
Yes, if you can manage yourself with exchanging the heads and the camplates of both pumps, then you should be done - though that might require reprogramming the ECU.
Reply #4February 17, 2010, 05:45:22 pm
CdnVWJunkie
  • 309
« Reply #4 on: February 17, 2010, 05:45:22 pm »
Reply #5February 18, 2010, 02:30:29 am
superspringer
  • 42
« Reply #5 on: February 18, 2010, 02:30:29 am »
This post should help out:
http://forums.tdiclub.com/showthread.php?t=152265
That's brilliant - thanks very much. Someone should copy that and post it on here on the FAQ page. Its very informative!!
And within that tdiclub post is a link to another walkthrough - this time with pictures:-
http://www.myturbodiesel.com/1000q_how_to/a3b4/injpumpswap.htm
Excellent reading.
« Last Edit: February 18, 2010, 04:34:39 am by superspringer »
Reply #6February 18, 2010, 05:23:34 am
CdnVWJunkie
  • 309
« Reply #6 on: February 18, 2010, 05:23:34 am »
Glad it helped. ;D
