Author Topic: 1996 Golf AAZ Serpentine Question  (Read 2538 times)
February 15, 2010, 05:59:43 pm
booneylander
  • 21
« on: February 15, 2010, 05:59:43 pm »
Driving along, serpentine belt blew. The tach quit, the oil pressure warning lamp started flashing, and the 'charge' light came on. I pulled over and parked the car out of the way and shut her down.
I got a new belt, and tried to get it on, but no joy.
The V belt is still on and ok, but in trying to look for pictures of the AAZ's pulleys, it looks as though I might have to pull the V belt off to slide the serpentine in?
Does anyone know how I need to do this?
On a related note, why did my oil pressure light come on? Why did the tach cut out? Seems to me the serpentine is just driving the alternator and the A/C pump. so why would it affect the other systems?
Is the oil pump driven off the serpentine?? I can't imagine this would be the case, but then again I've never worked on a vee-dub before. If the serpentine is only driving the alty and A/C, can I at least drive the car somewhere warm and dry, so I can work on it?
Cheers,
Sean
Reply #1February 15, 2010, 07:08:40 pm
jack's lack
  • 275
Re: 1996 Golf AAZ Serpentine Question
« Reply #1 on: February 15, 2010, 07:08:40 pm »
Your tach on a diesel in actually sensed by the alternator. Remember there is no distributor like on a gasser. The alternator has a "W" terminal that is used for the tach.
So that one was easy to explain. The charge light is of course a no-brainer.
The oil pump and the vacuum pump are driven by an auxiliary shaft via the timing belt, and if that broke you would have a whole lot more to worry about. I don't know why your oil light would be effected by this maybe just a change in voltage caused the light to go haywire?
What is the V-belt driving? power steering pump? Probably will be easiest to remove it. If it were me I would go ahead and do all the belts including the timing belt if I did not no the history. This is definitely an instance where an ounce of prevention would be worth a pound of cure.
If you are planning on keeping this car and doing any amount of work on it yourself, I would highly recommend investing in a Bentley publishing manual for the car. It will be an invaluable resource.
Good luck with your car Sean
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #2February 15, 2010, 08:05:03 pm
« Reply #2 on: February 15, 2010, 08:05:03 pm »
The oil pressure warning system pays attention to engine RPM via the W signal off the alternator as well, so the most likely scenerio is that the warning system got confused when the alt spun down.
Reply #3February 15, 2010, 08:28:56 pm
akrallysport
« Reply #3 on: February 15, 2010, 08:28:56 pm »
You're still Ok. As the others have mentioned the tach and other sensors are linked to the signal from the alternator. Loosen the PS pump, v-belt, install the serpentine, and re-install/tighten the v-belt and you should be set.
Reply #4February 15, 2010, 08:42:01 pm
GEE-BEE
  • 1604
« Reply #4 on: February 15, 2010, 08:42:01 pm »
For 15.00 dollars, Always carry a extra belt or two if you have a v-belt..
GB
Best of luck
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5February 15, 2010, 09:08:30 pm
booneylander
  • 21
« Reply #5 on: February 15, 2010, 09:08:30 pm »
Hey guys, thanks a ton for the insight!
With that in mind I'll probably drive the car someplace warm to work on it. Nothing quite like trying to do a job like this on the side of the road, in winter, in Ottawa...
