Author Topic: turbo upgrades for 1.6td  (Read 17144 times)
February 14, 2010, 11:00:13 am
Cynical 1
  • 13
    • http://www.cynicalmotorsport.com
« on: February 14, 2010, 11:00:13 am »
i've looked around this and other sites, but have had no real result...
what is a good all arund turbo upgrade for a 1.6td?
the engine is an ecodiesel from a '90 jetta. it will be rebuilt, and will have a real td pump from a 1.6td.
i have seen that the turbo on the eco is a K14 (?). it needs rebuilt, and that's why i'm thinking of an upgrade at this time...
i'm not looking to put down 200hp, but i want it to make about 100-120hp and be a little quicker...
just throw me some suggestions. thanks.
1979 Diamond Silver VW Rabbit C Diesel - low and slow.
1981 Cosmos Silver Scirocco S - dual carbed goodness.
1982 Burnished Gold VW Caddy LX Diesel - soon to be a TD.
http://www.cynicalmotorsport.com --- Facebook - Cynical Motorsport
http://www.zazzle.com/cynicalmotorsport - hats, T's, stuff
Reply #1February 14, 2010, 11:31:59 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: turbo upgrades for 1.6td
« Reply #1 on: February 14, 2010, 11:31:59 am »
The vnt15 is common, and if you set it up correctly can work really well for your setup.  I personlly am going to build a vnt 17/22 hybrid turbo with the exhaust from an euro only pd150 garrett gt 1749vb and the intake/compressor from a gt22.  There are a lot of vnt 15's out there on craiglook and so on but I don't know about any other turbos as I am highly interested in the zero lag and instant power concept. ;)
Reply #2February 14, 2010, 11:43:31 am
Kantdrivefast
  • 196
« Reply #2 on: February 14, 2010, 11:43:31 am »
No need for those. A K24 or T3 would be plenty big enough for that. I like my k24. Docile for driving around town, but put your foot into it and it'll boost to 20lbs in a hurry.
Reply #3February 14, 2010, 11:53:35 am
NintendoKD
  • 931
    • myspace page
« Reply #3 on: February 14, 2010, 11:53:35 am »
I just knew that someone would share their knowledge of conventional turboes, I hope all of this helps.
Kevin
Reply #4February 14, 2010, 11:58:48 am
Cynical 1
  • 13
« Reply #4 on: February 14, 2010, 11:58:48 am »
thanks.
but would the k24 or t3 mount to the factory exhaust manifold and clear the intake?
Reply #5February 14, 2010, 12:06:12 pm
Kantdrivefast
  • 196
« Reply #5 on: February 14, 2010, 12:06:12 pm »
thanks.
These are factory turbos. I'm almost certain that the k14 flange is different than both the t3 and k24. Easy enough to find a manifold though.
Reply #6February 14, 2010, 12:24:52 pm
MJF
  • 581
« Reply #6 on: February 14, 2010, 12:24:52 pm »
1,6/1,9td K14/K24/T2/T3 share same 4-bolt flanges. K03 is different, 3-bolt.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #7February 14, 2010, 04:46:18 pm
Kantdrivefast
  • 196
« Reply #7 on: February 14, 2010, 04:46:18 pm »
:) (thumbs up)
Wasn't quite sure which had the different flange.
Reply #8February 15, 2010, 02:03:40 pm
Cynical 1
  • 13
« Reply #8 on: February 15, 2010, 02:03:40 pm »
any specific trims for the tubo? will a t3 fit with the intake manifold, or would a spacer need to be mounted to move it farther away?
btw - the turbo on my engine is a K14.
Reply #9February 15, 2010, 09:56:11 pm
« Reply #9 on: February 15, 2010, 09:56:11 pm »
The K14 is a pretty solid turbo though for a 1.6... It's not ideal for making super high boost numbers but it'll handle something in the teens for a good long time with no issues.  If you've been running ECO then you'll probably get significant gains from chopping off your Cat and getting a real pump.
The T3/K24 can sustain higher pressures without grenading, but they spool up a lot slower, so it takes more to get the car moving.
Reply #10February 16, 2010, 10:26:48 am
arb
« Reply #10 on: February 16, 2010, 10:26:48 am »
I paid $300 for a new GT15 from Porthe after I got the used one from craigslist and it was locked up... I made my own flang and mounts:
http://www.vwdiesel.net/forum/index.php?topic=15633.0
It gives my 4,000 pound Caravan enough power to pull a 2,500 pound pop-up camper loaded with kayaks and such. I have the stock IP so far. Never any black smoke and plenty of power. I get above 40 mpg driving 70 - 75 mph every commute. Would love to see what a Giles would do for me ;-) When it gets warm again, I'll do some adjustments to the IP and turbo setup as I only get 10 psi boost.
Reply #11February 16, 2010, 12:09:57 pm
« Reply #11 on: February 16, 2010, 12:09:57 pm »
I've never personally seen an eco diesel but the T3, K24 etc should bolt right up. I think I remember reading that you will need a different oil return line as well.
Something to consider- The K14 from the 1.9 is a bit bigger then the one on the 1.6, it may be worth it to upgrade if you can find one.
