Author Topic: What size socket for injector?  (Read 17088 times)
February 13, 2010, 03:30:49 pm
mtnbob
  • 738
« on: February 13, 2010, 03:30:49 pm »
Just wondering if I can use a deep well socket or if I need a special tool, and what size socket?
86 VW Golf 1.6 N/A 4-door (soon to be turboed!!!)
http://farm4.static.flickr.com/3248/2598033828_d3d19f9842.jpg?v=0
96 Subaru Outback Wagon
Reply #1February 13, 2010, 03:37:13 pm
  • 3255
    • My collection of HOWTOs
Re: What size socket for injector?
« Reply #1 on: February 13, 2010, 03:37:13 pm »
Searching for "injector AND socket" revealed 4 pages of hits... here's one to get you started:
http://www.vwdiesel.net/forum/index.php?topic=1210.0
 ;) ;)  :D
« Last Edit: February 13, 2010, 03:39:24 pm by Vincent Waldon »
Reply #2February 13, 2010, 05:07:30 pm
rallydiesel
  • 1880
« Reply #2 on: February 13, 2010, 05:07:30 pm »
I use a run of the mill deep impact socket on 1.6 injectors. 1.9 injectors are taller so you might need some type of specialized socket. Or take the pump off and use a box wrench.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3February 13, 2010, 05:30:58 pm
mtnbob
  • 738
« Reply #3 on: February 13, 2010, 05:30:58 pm »
I read everything I could find and the closest thing was a "Craftsman 27mm deep socket", but not a current one ::) I guess this means there is no specialized tool that anyone knows of? Sorry to be a pest, just trying to do it right. ;D
Reply #4February 13, 2010, 05:55:26 pm
  • 3255
« Reply #4 on: February 13, 2010, 05:55:26 pm »
Nothing wrong with wanting to do things right, imho.  ;)
The Snap-On part number is S6104B... looks like this:
http://buy1.snapon.com/catalog/item.asp?store=snapon-store&item_ID=68171&group_ID=1326
Mac Tools makes one: SC141
Sykes in the UK makes one: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120414793352
Reply #5February 13, 2010, 09:31:39 pm
ein bora
  • 377
« Reply #5 on: February 13, 2010, 09:31:39 pm »
A regular deep socket didn't fit my 1.9 injectors, so I cut the end off and welded it to an old regular sized socket of similar size. The extra bit of depth works great and beat the cost of buying a specialized tool.
If you can't take advice - then you can't be helped!
Reply #6February 14, 2010, 12:57:03 am
« Reply #6 on: February 14, 2010, 12:57:03 am »
I use a 'Powerbuilt' 27MM deep 1/2" drive impact socket.
One of the injectors on the D14 is tight to the head, and i had to grind the nose of the socket to a small taper
Only drawback is you have to remove all  of the return line from the rabbit ears, or you can bend em with the socket.
this one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180377369193&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=d366d7c41250a0b583c3c4c3ff64f81f&rvr_id=&ua=WXF%3F&itemid=180377369193
« Last Edit: February 14, 2010, 12:58:44 am by 745 turbogreasel »
Reply #7February 15, 2010, 09:06:36 pm
commuter boy
  • 277
« Reply #7 on: February 15, 2010, 09:06:36 pm »
Just chuck a grinding stone into a drill and deepen and hog out the inside of the deep impact socket for the 1.9's.   Make sure you clear enough so the fuel return line barbs clear.
Reply #8February 15, 2010, 09:53:50 pm
wolf_walker
  • 1205
« Reply #8 on: February 15, 2010, 09:53:50 pm »
It depends on the socket's shape inside near as I can tell, but you CAN tweak the bypass line nipples and make them weep if you aren't careful.  Sometimes you can swedge them back in, sometimes not.  Go slow, be careful.
Mentat Text Two
Reply #9February 17, 2010, 12:48:33 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #9 on: February 17, 2010, 12:48:33 pm »
27mm also fits the oil cooler nut. Useful to know when the thing starts dumping oil into your coolant. ::)
Reply #10February 17, 2010, 10:16:46 pm
  • 2931
« Reply #10 on: February 17, 2010, 10:16:46 pm »
For the 1.6:
 1 1/16" deep socket
 Make sure it's 12 point;
 less likely to bend the little barbs
Reply #11February 19, 2010, 01:46:05 am
mtnbob
  • 738
« Reply #11 on: February 19, 2010, 01:46:05 am »
I purchased a 1/2" 27mm deep well 12pt socket from Lowes     Worked great for around $10  8)
Reply #12January 21, 2014, 07:58:47 am
BellCityDubber
  • 251
« Reply #12 on: January 21, 2014, 07:58:47 am »
just to keep this thread current...
the lowes Kobalt 1/2" drive 12 point 27mm deep socket will only work on the 1.6 injectors, it WILL NOT work on the longer 1.9 injectors.
Reply #13January 21, 2014, 08:13:12 am
« Reply #13 on: January 21, 2014, 08:13:12 am »
A short piece of cast iron pipe (cut off the end of my cheater pipe) and a couple minutes with my chop saw and welder fixed that...
It also leaves plenty of room for the return nipples.
« Last Edit: January 21, 2014, 08:14:46 am by libbydiesel »
