Author Topic: 1.6 TD with 1.9Td transmission  (Read 6508 times)
February 11, 2010, 04:08:27 pm
peacedub
  • 49
« on: February 11, 2010, 04:08:27 pm »
My 1.6td project is nearing the end, and i still dont have a tranny. I found a 93 plus jetta at the junk yard, its got a 1.9td in it and the tranny looks really fresh. Im thinking about getting it along with the driveshafts...
Has anyone had this combination on this car? Would it be much different from the 1.6 tranny?
Any advantages/disadvantages?
TIA. 8)
Reply #1February 11, 2010, 06:00:51 pm
GEE-BEE
  • 1604
Re: 1.6 TD with 1.9Td transmission
« Reply #1 on: February 11, 2010, 06:00:51 pm »
90 MM VS 100 MM  ?
Ratio to ratio
What do you have a FF ?
What is the other..
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2February 11, 2010, 06:35:06 pm
« Reply #2 on: February 11, 2010, 06:35:06 pm »
Reply #3February 11, 2010, 06:50:52 pm
peacedub
  • 49
« Reply #3 on: February 11, 2010, 06:50:52 pm »
thank you .
the 1.6 had a AGS in it. which had a pretty good gear ratio, want to get equavalent or better acceleration...but i also want a long 5th gear (i have a strait pipe and i want to enjoy my radio as well =])
AGS (86-90 1.6 Diesel)    3.94    3.45    1.94    1.29    0.91    0.75
The choice is between:
1.The 1.9Td tranny from a mk3 jetta
Im not sure what the code is for it
2.a 90 Jetta Diesel tranny
AWY ('90 Diesel)    3.94    3.45    1.94    1.44    1.13    0.89
3. Diesel Golf tranny
ACH ('85 1.6 Diesel)    3.94    3.45    1.94    1.37    1.03    0.75
i also have a GLI 9a close ratio trasmission but i think it would suck to have on a daily diesel has anyone ran one of these?
Reply #4February 11, 2010, 07:51:30 pm
Dakotakid
  • 1240
« Reply #4 on: February 11, 2010, 07:51:30 pm »
Wow, I can't imagine doing better than an AGS....unless an AGS with a 0.71 (although really wouldn't be much different).
I've run a lot of ACH's and AGS's and I prefer the deeper 4th and smaller step to 5th.
Or, get ahold of a gas ACN which is merely an ACH with different final. THAT should allow you to hear your radio!
Most guys report that ACN's are still plentiful. You might loose a little acceleration with it....so....get up earlier in the morning!
« Last Edit: February 11, 2010, 07:59:59 pm by Dakotakid »
Reply #5February 11, 2010, 08:17:26 pm
« Reply #5 on: February 11, 2010, 08:17:26 pm »
X2 on that one.
The AAZ will likely have a CHD or similarly geared box.
In my opinion a ASF, AON, ACN, ACL gearbox would be better then the AAZ box for 3 reasons
1- better reverse idler gear (mk3 boxes have a known problem with them)
2- see my quote from Dakotakid
3- 90mm flanges
Reply #6February 13, 2010, 04:56:58 pm
« Reply #6 on: February 13, 2010, 04:56:58 pm »
I've got an AAZ tranny behind a 1.6 in Jezebel... Mine's pretty bagged though (closing on 300,000 km)
1st sucks, there's not much in the way of acceleration there at all.  Once you're moving though it's ok.  It's a great highway transmission but I'd actually prefer something geared a little lower around town.  On the highway it's pretty much perfect - I spend most of my time right around 2K RPM give or take a few hundred in 5th.
