Author Topic: TD Inj. Pump?  (Read 5609 times)
February 09, 2010, 05:09:39 pm
Bludodger
  • 48
TD Inj. Pump?
« on: February 09, 2010, 05:09:39 pm »
Can anyone tell me if this pump is a true TD pump?
Sorry but I haven't the resource to find out.
VW#         068 130 109 (Q?)
Bosch#      046 049 4135
Should be a Quantum Pump...I think.
Thanks
PS Sorry for the double posting...not sure exactly where this fits.
if you need other numbers I have them.
PIC of Numbers on Pump:
http://s954.photobucket.com/albums/ae29/bludodger/?action=view&current=PICT0001.jpg&newest=1
« Last Edit: February 09, 2010, 10:30:06 pm by Bludodger »
Reply #1February 09, 2010, 05:13:27 pm
Re: TD Inj. Pump?
« Reply #1 on: February 09, 2010, 05:13:27 pm »
The number doesn't look right to me, it might help to post a pic of it.
Reply #2February 09, 2010, 05:22:42 pm
Bludodger
  • 48
Re: TD Inj. Pump?
« Reply #2 on: February 09, 2010, 05:22:42 pm »
Pic included in original post
Reply #3February 09, 2010, 07:11:32 pm
Re: TD Inj. Pump?
« Reply #3 on: February 09, 2010, 07:11:32 pm »
It looks like 068 130 109 Q to me.
Somewere in the FAQ is a thread about IP part numbers.
EDIT: I just found a big list of IP's and your's wasn't there, post a pic of the whole thing that might help.....or someone else might know by the PN what it is.
« Last Edit: February 09, 2010, 07:19:31 pm by rabbitman »
Reply #4February 10, 2010, 05:36:59 am
Bludodger
  • 48
Re: TD Inj. Pump?
« Reply #4 on: February 10, 2010, 05:36:59 am »
Thanks Rabbitman-- I knew there was a resource here just didn't know where it was...
Searched in FAQ for info--
I was able to find the pump on the bosch catalog (http://ecat-online.bosch.de/toc/frame1.html) but it didn't give me any info on what the specific application was. Did get this info though:
068-130-109Q = 0-460-494-135 =
VE4/9F2250R134-2
where...
V: Distributor injection pump
E: Axial piston high pressure pump or R: radial piston high pressure pump
2-6: Number of high pressure outlets
8-12: Pump plunger diameter in mm.
F: Mechanical governor or E: Electric actuator mechanism or M: high pressure solenoid valve.
2400: Upper pump nominal speed (half of engine rpm)
L: Counter clockwise or R: Clockwise (view toward pump drive)
12: Type code.
The Chinese Site (http://www.vepump.cn/CZB.htm) matched up the VW number to an engine code of SB...
CZ-B.494 267     0 460 494 267     068130110Q     VE4/9F2250R328-5     VW     SB
from what I read elsewhere in the forum SB is a GTD engine. This sounds unlikely since all indication is the pump came from an VW imported into USA.
So although I am further along the path I am afraid I still am not sure...
Can anyone else help me with this?
Reply #5February 10, 2010, 09:03:43 am
Re: TD Inj. Pump?
« Reply #5 on: February 10, 2010, 09:03:43 am »
If it's got the LDA it's a td pump, plus the clue to the SB says it's a td pump someone easily could've ordered it from over seas, you know ebay and such.
Reply #6February 10, 2010, 02:21:44 pm
ktzdsl
  • 73
Re: TD Inj. Pump?
« Reply #6 on: February 10, 2010, 02:21:44 pm »
Just had that exact pump rebuilt at Bosch shop. During discussion, he reminded me that I should check the Bentley for timing as the pump came off a 1985/86  TD Quantum.
DFW area Texas
1982 1.6L NA diesel pickup
Reply #7February 10, 2010, 03:56:02 pm
Bludodger
  • 48
Re: TD Inj. Pump?
« Reply #7 on: February 10, 2010, 03:56:02 pm »
Thanks ktzdsl-
Did he mention anything else about the pump? Any unique features or performance that this one has vs. standard jetta TD pump?
