Author Topic: What's the biggest battery.......  (Read 9589 times)
Reply #15February 09, 2010, 06:03:28 pm
GEE-BEE
  • 1604
Re: What's the biggest battery.......
« Reply #15 on: February 09, 2010, 06:03:28 pm »
I will  relocating the battery to behind the passenger seat, I will have to have some custom cables made, I search several websites, and it seems most of the shops also do welding cables also
Going with side mount post on the Optima
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #16February 09, 2010, 06:45:34 pm
« Reply #16 on: February 09, 2010, 06:45:34 pm »
I paid like $45 for the supercrank I have now, it's going on 4 years and I can tell on a cold day that it's seen better days.
Will size 34 fit? Or too tall?
Reply #17February 09, 2010, 07:30:06 pm
« Reply #17 on: February 09, 2010, 07:30:06 pm »
The only issues I have with the EVERSTART MAXX is the stock cable length, but on the last rabbit I went to 1/0 and longer...no issues.
Reply #18February 15, 2010, 11:17:09 pm
rabbid79
  • 684
« Reply #18 on: February 15, 2010, 11:17:09 pm »
I don't have any personal experience with this, but I've heard Odyssey batteries are excellent.  I have a diesel-nut friend who methodically researches every aspect of every component, and he says they're the best.  I believe that they're rebranded as "Diehard Platinum" as well?  They're considered a dry cell battery because of their construction, and can be mounted in practically any orientation.  They have excellent CCA, cold weather, and deep cycle capacity.  There's a datasheet somewhere on the internet for them if you want the details.  Anyway, this is just something I heard.  I plan on using one in my Audi when the time comes.
'15 WRX
Reply #19February 16, 2010, 07:53:59 pm
« Reply #19 on: February 16, 2010, 07:53:59 pm »
my brother works for a big battery company. he says that lithium batteries are good, but the recycling part is the real killer. apparently theres a lead acid battery in the works to compete with lithium. the battery contains a multiple of capacitors to lessen the stress on the battery. lithium batteries have no problems with high spike loads, but lead acid do.
i bet with a big 1 farad cap (install a toggle switch and a gauge so you know when its topped off) it would be a piece of cake starting in real cold. the cap could charge up while the glow plugs do their thing too...
then you don't need such huge batteries, although they are a good idea..!
Reply #20February 17, 2010, 08:04:49 am
« Reply #20 on: February 17, 2010, 08:04:49 am »
Well I just bought a size 41 interstate, 650cca. I wanted bigger but I couldn't find a size 34 with the terminals on the right side. I was getting desparate, 20F here lately so I don't plug in and it still cranks slow, 0F is supposed to be pretty easy.
Reply #21February 17, 2010, 09:18:50 pm
« Reply #21 on: February 17, 2010, 09:18:50 pm »
I have a hugge battery in mine :P
It used to start a 6.9 IH, so I figured it was good for my 1.6 ;) No clue on the CCA though :( but it doesn't fit properly, as can be told by the zip ties holding it in (temporary) lol
