Author Topic: Help, Please !  (Read 3074 times)
February 05, 2010, 03:13:23 pm
stewardc
Help, Please !
« on: February 05, 2010, 03:13:23 pm »
Hi
I just picked up a better-flowing TDI intake manifold for my non-TDI AAZ, and, being an old IDI guy, I am confused by all the openings in this manifold. What are the two openings for in the pictures below? Also, does anyone make blockoff plates for these holes?
Reply #1February 05, 2010, 03:16:37 pm
smutts
  • 720
    ClackClackClackClackClack
Re: Help, Please !
« Reply #1 on: February 05, 2010, 03:16:37 pm »
Betting EGR for the smaller one.
Reply #2February 05, 2010, 03:18:42 pm
Re: Help, Please !
« Reply #2 on: February 05, 2010, 03:18:42 pm »
Those two openings are for the EGR system... which is also why the manifold is full of black soot. ::)
The main EGR valve bolts onto the big hole... the smaller one is a feed thru the EGR water cooler.
There's an OEM part to block off the small one since industrial versions of the engine dont ship with that part of the EGR:  038 131 925
I've never seen a block off plate for the big one... folks just disable the vacuum that actuates the big valve and leave it in place.
« Last Edit: February 05, 2010, 03:21:22 pm by Vincent Waldon »
Reply #3February 05, 2010, 03:26:40 pm
GEE-BEE
  • 1604
Re: Help, Please !
« Reply #3 on: February 05, 2010, 03:26:40 pm »
ASK NICK AT STREETTOYS2000.COM ?
IF NOT CHECK OUT IDIPARTS.COM
Why didnt you just get a PD130 ?
I hope it was cheap to pay for the headache ?
G.B.
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4February 06, 2010, 04:44:25 am
stewardc
Re: Help, Please !
« Reply #4 on: February 06, 2010, 04:44:25 am »
G.B.
PD130 = $400
This manifold = CHEAP
Looks like I'll just cut a plug and weld it in. :)
Reply #5February 06, 2010, 06:57:09 am
ryanp
  • 269
Re: Help, Please !
« Reply #5 on: February 06, 2010, 06:57:09 am »
my manifolds are not $400! more like $240 next day delivery! yours is from a transporter van so you will need a custom block off plate as no-one i've seen has used them!
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #6February 06, 2010, 07:34:26 am
stewardc
Re: Help, Please !
« Reply #6 on: February 06, 2010, 07:34:26 am »
Mine is from a Passat. The intake is on the opposite side from most.
Reply #7February 06, 2010, 08:10:21 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: Help, Please !
« Reply #7 on: February 06, 2010, 08:10:21 am »
idiparts.com shows up as a motorcycle parts place FYI
Reply #8February 06, 2010, 08:51:29 am
GEE-BEE
  • 1604
Re: Help, Please !
« Reply #8 on: February 06, 2010, 08:51:29 am »
Oop's my bad IDPARTS.COM
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9February 06, 2010, 06:41:05 pm
ryanp
  • 269
Re: Help, Please !
« Reply #9 on: February 06, 2010, 06:41:05 pm »
my bad, the new 4pot transorters have those intakes, they get a little narrower ner to the ports compared to the PD150's. i can get intakes to face the cam or gearbox end!
