Temp Sensor Adapter : MKII/MKIII to MkI 1/8 NPT Adaptor
Topic: Temp Sensor Adapter : MKII/MKIII to MkI 1/8 NPT Adaptor (Read 2498 times)
February 03, 2010, 09:01:51 pm
GEE-BEE
February 03, 2010, 09:01:51 pm »
This adapter is for the MKII /MKIII style sensor
Toywagen.com us no longer making them
It is used on the later coolant necks 1.9
You can install the stock MKI type 1/8 npt sensor or a aftermarket type coolant sensor on this adapter.
I sent a email to Nick at Streetoys if he would be intersted in mfg this item.
Anybody else looking ?
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
February 03, 2010, 10:00:11 pm
NintendoKD
dnahtasinoivilboeraweb
Re: Temp Sensor Adapter : MKII/MKIII to MkI 1/8 NPT Adaptor
February 03, 2010, 10:00:11 pm »
picture? I don't know if I will need this? I have an aaz head but 1.6 cy block
February 03, 2010, 10:28:49 pm
February 03, 2010, 10:28:49 pm »
You only need this particular adapter if you're wanting to run the old-skool brass temperature sensors:
on the later coolant manifolds that are expecting the bigger cartridge-style temp sensors:
The adapter looks like this:
The owner of toywagens.com told me at the time that I bought his last one... sorry guys!!
Last Edit: February 03, 2010, 10:33:06 pm by Vincent Waldon
February 03, 2010, 10:38:08 pm
NintendoKD
February 03, 2010, 10:38:08 pm »
I don't even have a coolant neck yet.
Don't think that I will need this, though.
February 04, 2010, 05:24:15 pm
GEE-BEE
February 04, 2010, 05:24:15 pm »
Since no ones makes them now, Iam going to install both of the 1.6 type assys
Front housing will be for my aftermarket gauge (1/8 NPT ), side outlet will wire to the stock cluster gauge.
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
February 05, 2010, 07:27:15 am
dennis
February 05, 2010, 07:27:15 am »
Is there an OE part # for that adapter?
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
February 05, 2010, 07:32:11 am
GEE-BEE
February 05, 2010, 07:32:11 am »
TOYWAGEN ,said he might do a min production run of ten unit's
G.B.
Giles Pump OHC
MK1 JETTA DASH
February 05, 2010, 07:51:09 am
February 05, 2010, 07:51:09 am »
Quote from: dennis on February 05, 2010, 07:27:15 am
Nope... which is why the Toywagens of the worlds started to build 'em on the side.
