Author Topic: Clutch options for 1.9td help please  (Read 2276 times)
February 03, 2010, 05:54:57 pm
spencebm
  • 686
« on: February 03, 2010, 05:54:57 pm »
I have a 16v gas pressure plate and clutch disc for my 1.9 and I need to know what flywheel I can use and if I should have it resurfaced.  I also need to know what specs I need to tell the machine man to chop it down to.  Lots of people use a 210mm gas flywheel but what from?  2.0 ABA? 1.8 16v? 1.9td from canada?  Please help.  Thanks.
Ben Spencer
Reply #1February 03, 2010, 05:57:31 pm
Re: Clutch options for 1.9td help please
« Reply #1 on: February 03, 2010, 05:57:31 pm »
any gas engine with a 210mm flywheel will work as long as its for an 020 trans. just remember to get the timing mark put on it if it doesnt have one. and i remember someone saying to machine the big ring off the flywheel. the big thick ring in front of the ring gear.
Reply #2February 04, 2010, 03:23:09 am
Patrick
  • 1034
« Reply #2 on: February 04, 2010, 03:23:09 am »
Lots of threads on this. Resurface the flywheel if it looks shiny. I used the stock diesel flywheel (1.9) and cut the ring as far as I could while leaving the balancing cuts alone. Dropped the weight from about 14 lbs to about 10. Next one I do will be cut farther.
Reply #3February 05, 2010, 09:19:37 am
« Reply #3 on: February 05, 2010, 09:19:37 am »
usually people cut the front a little bit too.
Reply #4February 06, 2010, 04:48:04 am
stewardc
« Reply #4 on: February 06, 2010, 04:48:04 am »
I used the stock 1.9 flywheel (210mm). I've driven cars with a lightened wheel and didn't like it at all. I then installed a full ACT clutch assembly. At 220 Ft Lbs, I never have a slip. ;D
Reply #5February 06, 2010, 06:06:47 am
« Reply #5 on: February 06, 2010, 06:06:47 am »
http://www.clutchnet.com/home.php
I got one from these guys. Talked to a guy named George (sounded like it should have been Horhey) anyhow pretty much anything they do they will custom make for you. I got a 210mm sprung hub 6 puck disc with a red 210 pp...just make sure it is all the correct spline no matter where you get it.
