Author Topic: Oil Pump  (Read 2363 times)
February 03, 2010, 07:54:16 am
ein bora
  • 377
Oil Pump
« on: February 03, 2010, 07:54:16 am »
Does anybody know which oil pumps are interchangeable with the 1.9 IDI oil pumps?? They all look fairly similar - and the gas oil pumps seem to be easier and less money to get.
If you can't take advice - then you can't be helped!
Reply #1February 03, 2010, 08:06:13 am
Re: Oil Pump
« Reply #1 on: February 03, 2010, 08:06:13 am »
but they spin the wrong way. you need a 36mm diesel oil pump. or just order the right one.
Reply #2February 03, 2010, 09:46:55 am
ein bora
  • 377
Re: Oil Pump
« Reply #2 on: February 03, 2010, 09:46:55 am »
Okay thanks. Good thing I checked.
Reply #3February 03, 2010, 09:56:32 am
truckinwagen
  • 1895
Re: Oil Pump
« Reply #3 on: February 03, 2010, 09:56:32 am »
nope, the gas ones spin the same way.
the im shaft spins the other direction, but the gear on the end is cut the other direction, so the gas and diesel oil pumps spin the same way.
the issue, however, is that the gasser oil pumps have a shorter shaft, and don't engage the drive in the vacuum pump.
83 Opel Kadett Diesel
Reply #4February 03, 2010, 10:00:52 am
Re: Oil Pump
« Reply #4 on: February 03, 2010, 10:00:52 am »
oh yea, forgot about the reverse cut gears for the diesel oil pump. but i knew something was different making it not do-able.
