Author Topic: blb/bkp oil pressure  (Read 3991 times)
February 02, 2010, 05:46:07 pm
oldskool rich
  • 446
« on: February 02, 2010, 05:46:07 pm »
at work ive had alot of trouble with these 2.0 16 valve engines, built one perfectly with new bearing and oil pump, as soon as the customer installed it oil light came on, no reason why, changed the oil pump, and still ***ed.
anyone know where im going wrong? do the blocks or heads go wrong? if so where and can they be fixed? im at my witts end VW wont admit theres a common problem with anything
please help
f6squared I.D.S.T
Reply #1February 02, 2010, 11:02:47 pm
rolo
  • 40
Re: blb/bkp oil pressure
« Reply #1 on: February 02, 2010, 11:02:47 pm »
Try priming oil pump. I have been known to pressurise the sump oil with compressed air, low press.mind the oil seals. Had to do this on various engines over the years v8 rovers, vauxhall cavs., golfs random really.
the last one
Reply #2February 04, 2010, 04:21:31 pm
oldskool rich
  • 446
« Reply #2 on: February 04, 2010, 04:21:31 pm »
i dont think this is the case, they run ok, just wen you rev them the oil light cums on. rest of the time oil pressure isnt low enough to be a problem
its using the same oil pump as all the other PD engines
f6squared I.D.S.T
Reply #3February 04, 2010, 11:18:38 pm
rolo
  • 40
« Reply #3 on: February 04, 2010, 11:18:38 pm »
So oil light comes on with ign. goes out when started then comes back on at high revs? Have you fitted a pressure gauge to see exactly whats happening?
the last one
Reply #4February 05, 2010, 09:38:50 am
oldskool rich
  • 446
« Reply #4 on: February 05, 2010, 09:38:50 am »
its not me its a garage that bort the engine off us, happend twice now, dunno if they used a gauge yet, what should it be?
f6squared I.D.S.T
Reply #5February 06, 2010, 02:02:17 pm
rolo
  • 40
« Reply #5 on: February 06, 2010, 02:02:17 pm »
sat night no info here .if it happened to me I`d think are they taking the piss.
the last one
