Author Topic: cruise blues  (Read 3903 times)
November 13, 2005, 07:08:07 am
albsure
cruise blues
« on: November 13, 2005, 07:08:07 am »
hi guys, my cruise control just would not work it only came on twice. both times on the same stretch  of road on a down grade.  :mad:
so i did a search on the forums and read everything i could find about cc, and vacuum lines. long story short, a hole rubbed in the vacuum line AND a faulty break light switch. now i can make it work every time :D  :D .
i say make it work because i have to play with the switch :confused: buttons on the  control lever. ???? is there any way that the switch can be taken apart to clean the contacts ???? i want it to work right all the time.
i would really appreciate any info you can give from your experience because the bentley does not give much info on it. thank you all. Al b sure.
