Author Topic: Wider stance on A2?  (Read 4309 times)
November 13, 2005, 06:27:25 am
Laurentian
Wider stance on A2?
« on: November 13, 2005, 06:27:25 am »
Hi, heard of some people doing an axel beam and A-arm awap on A2 using A3 parts for an additional 1/2" track per side.
Of course this seems a bit much trouble for me but I have a complete A3 for my motor swap on hand.
Is this a good set-up or could I just use wheel spacers with my teardrops for a nicer look? I have a set of FK 1.5 sports springs to round off the set-up.
Thanks,
Hugh
Reply #1November 13, 2005, 01:07:53 pm
vwmike
  • 1158
Wider stance on A2?
« Reply #1 on: November 13, 2005, 01:07:53 pm »
The MK3 control arms, axles, and tierods are longer. Yeah, you can swap all of this stuff but I don't think I'd bother if I were you. It will likely make the tires rub.
Reply #2November 18, 2005, 06:51:02 am
houseofdiesel
  • 210
Wider stance on A2?
« Reply #2 on: November 18, 2005, 06:51:02 am »
You can swap the rear axle for a wider track, apparently a good upgrade if your serious about handling/solo events etc.
Reply #3November 18, 2005, 10:04:07 am
greggearhead
  • 153
Wider stance on A2?
« Reply #3 on: November 18, 2005, 10:04:07 am »
Quality spacers will allow you to try this out for minimal investment of time and $$.
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
