Author Topic: Flashing Temp Light  (Read 5262 times)
January 30, 2010, 11:30:21 pm
Big Daddy Roth
  • 298
Flashing Temp Light
« on: January 30, 2010, 11:30:21 pm »
The temp light on my AAZ B3 is constantly flashing. Doesn't come on right away. But after abotu 30sec of driving it starts flashing. I've swapped in a new coolant temp sensor. I have also checked the reservoir sensor. I unplugged the connector and shorted the two pins together, no change.
I'm stumped.
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1January 31, 2010, 06:10:12 am
Doug
Re: Flashing Temp Light
« Reply #1 on: January 31, 2010, 06:10:12 am »
Clean your reservoir sensor as in remove it and clean it with hot water and soap. You may have an oil film in there that is causing it to not work. then clean the reservoir with hot soapy water. Refill before trying again. Check reservoir sensor leads for breaks at the spade connectors.
Reply #2January 31, 2010, 09:24:11 am
Big Daddy Roth
  • 298
« Reply #2 on: January 31, 2010, 09:24:11 am »
I already eliminated that problem with the reservoir. I took the connector off, and shorted the two pins together. That should have stopped the flashing, but it didn't.
1993 TD B3 Sedan
Reply #3January 31, 2010, 09:52:25 am
« Reply #3 on: January 31, 2010, 09:52:25 am »
This suggests that the issue could be a break in the wiring upstream of the sensor... often at the connector itself.
BTW, the flashing LED also signifies an overheat situation... what's your temperature gauge saying?  Could be the temp circuitry in the cluster is misbehaving.  :P
Reply #4January 31, 2010, 10:01:38 am
Big Daddy Roth
  • 298
« Reply #4 on: January 31, 2010, 10:01:38 am »
Yes, I suspect the cluster is poop too. I did swap the voltage reg when I got the car.
My temp gauge is reading correct.
I'll check the wiring.
I really wish my passat Bentley covered the AAZ. Does anyone know where I can find a book that does?
1993 TD B3 Sedan
Reply #5January 31, 2010, 10:11:59 am
« Reply #5 on: January 31, 2010, 10:11:59 am »
The A3 Jetta/Golf Bentley manual (red cover) covers the AAZ engine in depth. It's vague on the nuances of the EGR and emissions stuff, unfortunately, so I wouldn't recommend buying it if that's all you're really trying to track down... but for everything else it's the bible.
Reply #6January 31, 2010, 10:23:33 am
Big Daddy Roth
  • 298
« Reply #6 on: January 31, 2010, 10:23:33 am »
Yeah I have the mk3 book as well. It's doesn't really help me in cases like this. I need something that covers the B3 AAZ.
1993 TD B3 Sedan
Reply #7March 22, 2010, 04:58:09 pm
Big Daddy Roth
  • 298
« Reply #7 on: March 22, 2010, 04:58:09 pm »
FIXED!
I pulled the cluster back out and fired up my soldering iron. Found a couple of cracked connections.
No more flashing light. Everything works like a charm.
......except now my clock illumination is intermittant  :-\
1993 TD B3 Sedan
