Author Topic: Terrible starting issues in cold weather.  (Read 3919 times)
January 30, 2010, 02:00:43 pm
Sixdown
  • 10
« on: January 30, 2010, 02:00:43 pm »
My 85 Jetta Diesel has issues starting in all weather below 45 degrees Fahrenheit.  I just tried starting it in 15 degree weather and ran down the battery trying to start it, which is what usually occurs and I have to keep jumping it (The battery is new).  Once it starts, if it does, it smokes like hell for a few minutes and then runs perfectly.  I have used the cold-start knob every time.
What is the problem with my car?  Injection timing?
1985 VW Jetta Deluxe 1.6 NA
Reply #1January 30, 2010, 02:16:06 pm
Re: Terrible starting issues in cold weather.
« Reply #1 on: January 30, 2010, 02:16:06 pm »
If you're getting really good cranking speed your battery, starter, and the connections in between are probably fine.
The usual two suspects of "starts hard when cold, smokes like a chimney, fine when warm" are the glowplug system and timing...I'd say 80/20 in favor of the glowplugs.  ;)
Glowplug troubleshooting info here:
http://vincewaldon.com/index.php?option=com_content&task=view&id=41&Itemid=28
Checking/setting timing info here:
http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
Reply #2February 03, 2010, 01:19:10 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #2 on: February 03, 2010, 01:19:10 pm »
The usual two suspects of "starts hard when cold, smokes like a chimney, fine when warm" are the glowplug system and timing...I'd say 80/20 in favor of the glowplugs.  Wink
X2 ;)
Reply #3February 05, 2010, 07:24:09 am
Op-Ivy
  • 513
« Reply #3 on: February 05, 2010, 07:24:09 am »
I was having hard cold starting issues recently as well. Turns out two of my glowplugs were dead. The buggers...
