Author Topic: GM 6.6L Duramax Loss of power  (Read 13113 times)
January 30, 2010, 01:26:42 pm
catlin_cava
  • 1954
« on: January 30, 2010, 01:26:42 pm »
OK its a 6.6L duramax turbo diesel.
267,000kms on it
1st to 3rd I have power right to my fuel governer at 3500RPM,
4th to 6th I loose power when i get around 1700RPM if my foot is into it. If I come into it lightly i have more power but you don't hear the turbo. when I give it a bt harder the truck buggs and all you hear is the turbo whistle.
6th itself has hardly anypower.
The truck was working great this morning, then it started acting up
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1January 30, 2010, 09:22:52 pm
Re: GM 6.6L Duramax Loss of power
« Reply #1 on: January 30, 2010, 09:22:52 pm »
Quote from: CatlinGun
There's your problem CatlinGun
Can't rely on anything post-1992 ;)
« Last Edit: January 31, 2010, 07:43:08 am by 8v-of-fury »
Reply #2January 31, 2010, 07:39:57 am
catlin_cava
  • 1954
« Reply #2 on: January 31, 2010, 07:39:57 am »
I now have no power above 2000RPM even in neutral.
Catlin
Reply #3January 31, 2010, 07:44:24 am
« Reply #3 on: January 31, 2010, 07:44:24 am »
Whoa.. this is the same truck that had the gauges flying all over the place right!?!?
Maybe it's finally time for your boss to have it in for work? What were his words.. "don't come to me unless there is a real problem" ??
I think this about qualifies :P
Reply #4January 31, 2010, 08:15:03 am
catlin_cava
  • 1954
« Reply #4 on: January 31, 2010, 08:15:03 am »
CEL is on and he doesn;t want us reving over 2000RPM...It feels like my fast idle is on but its not....
Catlin
Reply #5January 31, 2010, 09:01:35 am
« Reply #5 on: January 31, 2010, 09:01:35 am »
fuel problem of some sort. or a sensor. these older GM's are kinda picky. what engine does it have in it? an LLY?
Reply #6January 31, 2010, 09:17:11 am
catlin_cava
  • 1954
« Reply #6 on: January 31, 2010, 09:17:11 am »
I fueled yesterday morning at the I24 Cardlocks(Irving Cardlocks) about 45 minutes later i started getting problems with the truck. Now I can rev again in neutral and back to the orginal problem. The boss told me to dump 2 canisters of gasline antifreeze.
The other drive has had problems there before also. and Nat's (my gf) family as had problems with Irving fuel with water in the trucks also.
Catlin
Reply #7January 31, 2010, 09:22:39 am
« Reply #7 on: January 31, 2010, 09:22:39 am »
kinda almost seems like a water issue. try draining the fuel filter and see what comes out?
Reply #8January 31, 2010, 09:54:24 am
catlin_cava
  • 1954
« Reply #8 on: January 31, 2010, 09:54:24 am »
I ran the stuff in the system and the CEL is now off, and I've got a bit more power, its still bugging out in 4th and 5th. If I feather the peddal I get more power. Its going to the dealer tomorrow.
Catlin
Reply #9February 01, 2010, 06:30:10 am
« Reply #9 on: February 01, 2010, 06:30:10 am »
It does sound like it could be contaminated fuel. Let us know what the dealer says
Reply #10February 01, 2010, 07:16:51 am
catlin_cava
  • 1954
« Reply #10 on: February 01, 2010, 07:16:51 am »
Well the boss hasn't touched or moved the truck, if he doesn't take it to the dealer i'm going to drive it till it dies, and let him learn his lesson.
Catlin
Reply #11February 02, 2010, 10:13:59 am
catlin_cava
  • 1954
« Reply #11 on: February 02, 2010, 10:13:59 am »
The boss dropped it off yesterday at GM...turns out the fuel filter was plugged solid. replaced the filter and VOLA the truck works great again
Catlin
Reply #12February 03, 2010, 07:49:16 am
« Reply #12 on: February 03, 2010, 07:49:16 am »
someone else could have checked this and saved the hassle. lol
Reply #13February 03, 2010, 08:49:13 am
catlin_cava
  • 1954
« Reply #13 on: February 03, 2010, 08:49:13 am »
Yes I Could of checked that, but my limit of maintance on the truck is to check the oil and fill the washer fuild. We dont do work on our trucks
Catlin
Reply #14April 11, 2010, 09:59:12 pm
FoXBoXRaCiNG
  • 92
« Reply #14 on: April 11, 2010, 09:59:12 pm »
Every 25kkm for fuel filter (asIdo) and I spin on a fresh tranny filter for the sake of 15 bux!!! I've read done lot's from here:
http://www.duramaxforum.com/forum/
My cat has A.D.D :(
