Author Topic: FS: Complete Garrett GT1544/AAZ manifold setup for 1Z/AHU Vanagon 50*  (Read 6245 times)
January 29, 2010, 09:53:22 am
fairweather
  • 85
    • TDI Syncro
This is for installation of a 1Z or AHU TDI in a vanagon at 50 degrees. This setup flips the turbo up to allow for correct oil drainage and clearance for the stock DV engine bracket.
Includes:
GT1544 rebuilt/balanced by G-Pop Shop
CNC adapter plate
3 bolt AAZ manifold
oil drain/supply fittings (will need M18x1.5 to -AN10 plus section of hose for block connection or banjo fitting)
oil supply line
silicone reducer for compressor inlet
stock piping for compressor outlet
discharge flange with starter 2.5" pipe + gasket
650$
tom.verry at gmail dot com
« Last Edit: June 03, 2011, 06:12:31 am by fairweather »
83 Caddy with CY code 1.6TD out of a rabbit.
Reply #1February 08, 2010, 06:27:01 am
fairweather
  • 85
    • TDI Syncro
Re: FS: Complete Garrett GT1544/AAZ manifold setup for 1Z/AHU Vanagon 50*
« Reply #1 on: February 08, 2010, 06:27:01 am »
bump
Reply #2June 03, 2011, 06:12:53 am
fairweather
  • 85
    • TDI Syncro
bump, new price
Reply #3November 03, 2011, 09:11:32 am
fairweather
  • 85
    • TDI Syncro
« Reply #3 on: November 03, 2011, 09:11:32 am »
bump
