Author Topic: How to fix a backup light switch.  (Read 6789 times)
January 28, 2010, 10:19:09 pm
« on: January 28, 2010, 10:19:09 pm »
Here: http://www.brokevw.com/reverseswitch.html is all the pictures and some good info.
The link shows how these go bad and sorta how to fix 'em.
But what I did after having the backup lights start flickering again after putting in a new switch only 2ish years ago, is I took the switch apart, cleaned the burnt contacts as good as I could and then flipped the "button" over.
The reverse button is the farthest forward one when it's installed, and only the mk1/four wire switch is easy to disassemble, all the others are glued/welded together.
After doing this either relay the backup lights or get LED bulbs, I've never seen 'em just heard about 'em....
Reply #1February 01, 2010, 09:32:27 am
clbanman
  • 705
    Cambridge, Ontario
Calvin
91 VW Golf 1.6NA 5spd
Reply #2February 03, 2010, 07:32:51 pm
Re: How to fix a backup light switch.
« Reply #2 on: February 03, 2010, 07:32:51 pm »
After driving around with the switch fixed by this method I've noticed the backup lights will come on in 5th gear when I first hit that gear or hold the shifter far into 5th.
