TDI Engine -General Info
Disco pump electronic cold boost?
Topic: Disco pump electronic cold boost? (Read 4517 times)
January 25, 2010, 04:09:41 pm
svenakela
January 25, 2010, 04:09:41 pm »
Finally my baby is at home, it looks like a pump in good shape.
It seems it has a kind of cold start boost, the one with the cable attached. Does anyone know what the pins in the connector are and if it is driven with a PWM-signal?
There's another connector as well (the right one), I assume that is the fuel temp sensor. Am I right?
January 25, 2010, 06:13:13 pm
CdnVWJunkie
Re: Disco pump electronic cold boost?
January 25, 2010, 06:13:13 pm »
Not sure about the 1st plug but the second one is fuel cut off isn't it?
January 25, 2010, 07:13:36 pm
January 25, 2010, 07:13:36 pm »
First one is a throttle position sensor used for automatic transmissions I think.
Second is definitely the stop solenoid.
January 25, 2010, 11:09:25 pm
snakemaster
January 25, 2010, 11:09:25 pm »
you dont need the first on on a mtdi but you need your stop solenoid power to run and no power to stop the fuel
Glenmorangie single highland malt
January 26, 2010, 01:49:43 am
svenakela
January 26, 2010, 01:49:43 am »
Ah! A TPS and the Cut off valve. I totally missed that.
Anyway, it got me thinking. A TDI use to rely on glowing for cold starts.
Thanks guys!
January 26, 2010, 02:30:37 pm
blackdogvan
January 26, 2010, 02:30:37 pm »
Keep it & all the hardware, you never know when someone will make a electronic VNT controller that uses that TPS.
1991 Vanagon 1.9 mTDI
January 26, 2010, 02:38:35 pm
svenakela
January 26, 2010, 02:38:35 pm »
You mean like
these guys
But yes for sure I'll save it.
January 26, 2010, 02:56:59 pm
blackdogvan
January 26, 2010, 02:56:59 pm »
No like this guy...
http://www.vwdiesel.net/forum/index.php?action=profile;u=10152
January 26, 2010, 10:02:51 pm
rolo
User+
January 26, 2010, 10:02:51 pm »
^Contact regcheeseman
the last one
January 29, 2010, 09:56:16 am
ryanp
January 29, 2010, 09:56:16 am »
i sent my mate all the stuff to make a M-tdi pump with the disco TPS, dont know when it will be done though!!
RY
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
