Author Topic: Question re: front suspension (struts).  (Read 5992 times)
January 25, 2010, 02:23:04 pm
veedubcanuck
  • 151
« on: January 25, 2010, 02:23:04 pm »
 I'm just wondering what the difference is between the front Struts (mainly the coil springs) on a 91 Jetta diesel vs a gasser. It appears that they are different?? Why? The engines can't weigh that much more in a diesel?
 Thanks!
Reply #1January 26, 2010, 09:30:21 am
clbanman
  • 705
    Cambridge, Ontario
Re: Question re: front suspension (struts).
« Reply #1 on: January 26, 2010, 09:30:21 am »
Per post in http://www.vwdiesel.net/forum/index.php?topic=20825.15
1600cc(Gas)-159.2 Pds
1835cc(Gas)-160.3 Pds
1835cc(Gas-Turbo)-181.1 Pds
2180cc(Gas)-164.5 Pds
2393cc(Gas)-188.0 Pds
2792cc(Gas)-197.3 Pds
2792cc(Gas-Supercharged)243.8 Pds
1588cc(Diesel)-277.3 Pds
1588cc(Diesel-Turbo)-283.7 Pds
1896cc(Diesel)-282.9 Pds
1896cc(Diesel-Turbo)-297.0 Pds
Calvin
91 VW Golf 1.6NA 5spd
Reply #2January 26, 2010, 03:18:22 pm
veedubcanuck
  • 151
« Reply #2 on: January 26, 2010, 03:18:22 pm »
Perfect! Thanks!
Reply #3January 27, 2010, 07:57:01 pm
« Reply #3 on: January 27, 2010, 07:57:01 pm »
I take it "Pds" is supposed to mean lbs?
Are these all water cooled engines?
I have a hard time believing that a 1.6 gasser weighs 120lbs less than a 1.6 diesel.
Is the 2792cc a VR6?
Reply #4January 28, 2010, 04:16:43 am
rs899
  • 647
« Reply #4 on: January 28, 2010, 04:16:43 am »
I agree- the 8v gasser and diesel should be just about the same.  What are the differences? Injectors? IP?  The basic block head and moving components can't be more than 5-10 pounds apart....
Reply #5January 29, 2010, 09:17:53 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #5 on: January 29, 2010, 09:17:53 am »
My post was a strict copy and paste after a search on the forum.   FYI, per http://www.haywood-sullivan.com/vanagon/TDI/tdi_specs_en.pdf, a VW AFD 1.9 industrial engine weighs about 135 kg dry.
Calvin
Reply #6January 29, 2010, 09:24:52 am
truckinwagen
  • 1895
« Reply #6 on: January 29, 2010, 09:24:52 am »
the weight difference comes from the diesel block having much more reinforcement cast into it, and that the cranks, unlike many gasser cranks, are fully counterweighted.
that and the extra weight of the injectors, injection pump, vacuum pump, intake manifold, etc... it all adds up.
100LB difference is not all that much when you consider the weight of the cast iron used in the block.
83 Opel Kadett Diesel
