Author Topic: 2010 Edition of the Governor Mod  (Read 330045 times)
Reply #135March 28, 2012, 03:12:49 pm
Re: 2010 Edition of the Governor Mod
« Reply #135 on: March 28, 2012, 03:12:49 pm »
peak torque for my engine happens at 2400 rpm. Will this mod  change it?
Well with this mod you are not really changing the engines characteristics. So the engine should behave very similarly, just have more power at all rpm's, and especially above 2500rpm. With the eco pump you will never be able to physically move as much fuel as a normal 1.6 NA or 1.6TD pump, because you have the 8mm fuel head and they have the 9mm. But this governor mod will help you move significantly more than you were moving before :)
Reply #136April 02, 2012, 06:47:21 pm
92EcoDiesel Jetta
« Reply #136 on: April 02, 2012, 06:47:21 pm »
Did the governor mod with a stainless steel 2.5 mm thick nut on the main spring as recommended here (thanks for the write up 8V).
Lot more power but also a lot more smoke if I gun the pedal. Love the extra power but it has an erratic idle. Sometimes it would be real low- to the point of stalling if I don't feather the throttle. Other times it would idle between 1500 to 1800 rpm. I tried adjusting the idle and fuel screw which didn't help. What did I screw up in the mod?
Here are some pics:
I made a spring compressor to make the job easier and no flying parts.
This pic shows 2 nuts. I took one of them off before installing.
I also had this emergency shut off ready in case I get a runaway. I tested it and it works! Shuts engine off in a split second.
Before pulling the cover off, I sucked some fuel out via the Out bolt so as not to spill any diesel.
« Last Edit: April 02, 2012, 06:49:34 pm by 92EcoDiesel Jetta »
Reply #137April 02, 2012, 06:55:36 pm
« Reply #137 on: April 02, 2012, 06:55:36 pm »
So for clarity, I see that you have used two nuts on the main spring of the governor as per this write-up.
Don't suppose you grabbed a picture of it back in the throttle lever cage/piece??
Reply #138April 03, 2012, 04:30:04 am
92EcoDiesel Jetta
« Reply #138 on: April 03, 2012, 04:30:04 am »
I used 2 nuts but took one out before installing it in the pump because it was too thick and made it difficult to insert the C-clip.
The one on the left with one nut is the modded governor for the EcoDiesel. The one on the right is from a Peugeot parts pump that I practiced on before working on the Eco.
Reply #139April 04, 2012, 05:45:35 pm
92EcoDiesel Jetta
« Reply #139 on: April 04, 2012, 05:45:35 pm »
Problem fixed!
Reply #140April 04, 2012, 05:47:09 pm
« Reply #140 on: April 04, 2012, 05:47:09 pm »
Problem fixed!
Please share your fix so that others coming to the thread may be able to solve their identical problem :)
Reply #141April 04, 2012, 09:05:07 pm
« Reply #141 on: April 04, 2012, 09:05:07 pm »
I had to reseal so I shimmed mine 1 old DV washer.  It works, and the D24T will now rev I don't know how high...
Is still pulling at 5500 though.
I'm an idiot, and changed more than one thing at a time so....who knows...  At least it is faster than before, and doesn't leave a foot long pool of fuel when I park.
« Last Edit: April 04, 2012, 09:08:22 pm by 745 turbogreasel »
Reply #142April 04, 2012, 09:14:35 pm
ToddA1
  • 434
« Reply #142 on: April 04, 2012, 09:14:35 pm »
Is that a copper sealing washer that you used?  I'd be leery of the spring wearing into it and having metal shavings in the pump.
-Todd
Reply #143April 05, 2012, 01:13:02 pm
« Reply #143 on: April 05, 2012, 01:13:02 pm »
I'll be looking at it again soon enough, and will give it a good look over.
Reply #144April 05, 2012, 05:40:40 pm
92EcoDiesel Jetta
« Reply #144 on: April 05, 2012, 05:40:40 pm »
Problem fixed!
I didn't want to provide details until I drove it a bit to make sure it is really fixed. It was due to binding in the high speed idle lever of the cold start advance/ high speed idle system. When I took the pump cover off, I took the high speed idle lever off when I should have left it on and unhook the speing loaded rod instead. During reassembly, the o-ring on the high speed idle lever partially unseated and got pinched, causing it to bind. It also leaked a little fuel. After taking the cover off and reseated the o-ring the idle is normal.
The governor mod made my Jetta feel like a different car! It has substantially more power. If I mash the pedal I get lots of black smoke (none before) and the car just takes off with a lot more pep. I've been driving it with slow and steady acceleration in order to avoid smoke, which still gives much better power and acceleration than before. It is a completely different driving experience, more relaxed- less down shifting. On the hills that I drive often, I used to have to anticipate and speed up to 80 mph before approaching in order to make the top and maintain 60 mph without having to down shift. Now I stay in 5th w/o having to speed up and rely on momentum to make the top of the hill and maintain 60. I think I am getting better fuel economy also by being able to stay in 5th more often. Love the mod!
Reply #145April 30, 2012, 07:13:14 am
92EcoDiesel Jetta
« Reply #145 on: April 30, 2012, 07:13:14 am »
The governor mod been doing ok since I fixed the high idle issue. Although I do notice some changes such as I seem to have less smoke now than immediately after the mod. I also sometimes get a low idle after dropping from a high RPM.
I am going to try a solid shim to see if it corrects the low idle problem.
I want to make the solid shim out of Delrin. From what I can see, the shim is always under compression and there should not be any movement between the Delrin and seats in operation so I should not have any wear problems. The force on the Delrin is not that great, just the intermediate spring so I think it should be fine. Any opinions?
Reply #146April 30, 2012, 05:14:38 pm
« Reply #146 on: April 30, 2012, 05:14:38 pm »
There is two larger springs in the head of the pump that the governor has direct force on. The governor pulls on that lever that it slides into, and then that lever has two tough springs at the bottom of it which get compressed when you push more pedal. So there is actually quite the force that will be on whatever you use as your shim.
Reply #147April 30, 2012, 08:06:47 pm
92EcoDiesel Jetta
« Reply #147 on: April 30, 2012, 08:06:47 pm »
I don't know the internals of the pump very well as far as what pushes on what. I am just a nooby student of VE pumps.
Here's a link to Delrin specs
http://www.plasticsintl.com/datasheets/Delrin_150.pdf
compressive strength is 5200 psi
Do you think the force on the shim is greater than that?
Reply #148May 01, 2012, 10:32:00 am
« Reply #148 on: May 01, 2012, 10:32:00 am »
i would still use metal to shim the governor..
plastic inside an injection pump kinda scares me.. look at the old DB2 flex ring governors.. plastic.. that was the reason 99% of the 5.7D & 6.2D engines died and were never fixed..
Reply #149May 01, 2012, 02:09:18 pm
« Reply #149 on: May 01, 2012, 02:09:18 pm »
A copper or brass washer wouldn't even make a roller skip if pieces of it were thrown in its way.
