Author Topic: Alternator ( 1.9 70 AMP OR 90 Amp / 120 AMP  (Read 2910 times)
January 21, 2010, 06:00:05 pm
GEE-BEE
  • 1604
« on: January 21, 2010, 06:00:05 pm »
I just got my alt brackets back from the powder coater ( silver )and I have a new 120 amp for the A/C  system if I install that.
Iam going with the stock 70 amp and I dont want to hang a  unit on there I know nothing about., I wasnt easy since the mounting bolt on one of ears would not come all the way out since it not clear the frame on my MK1 caddy.
I removed all four nuts from the alt bracket and removed it as a complete assy, not bad since the pump is off and the bracket is being PC satin black..
I went to the German auto parts website and they dont carry alternator's ?
Best price exchange is AutohausAZ 150.86 ?
Any others ?
Model 028-903-025 G ( ALO 187 X )
90 AMP MODEL            ALO 181 X
Spring plunger type
GB
« Last Edit: January 24, 2010, 08:37:05 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1January 22, 2010, 09:05:21 am
GEE-BEE
  • 1604
Re: Best source to purchase a New Alternator ? ( 1.9 AAZ 70 amp )
« Reply #1 on: January 22, 2010, 09:05:21 am »
ALO181 X ( 90 AMP ) NON-A/C MODEL IS INTERCHANGEABLE TO ALO185X ( 70 AMP )
AUTOHAUS AZ carries the Bosch Overhauled unit's: 1 YEAR REPLACEMENT, 2 YEAR ROADSIDE PROTECTION
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #2January 24, 2010, 08:34:14 pm
GEE-BEE
  • 1604
Re: Alternator Bracket ( 1.9 AAZ 70 AMP OR 90 Amp / 120amp )
« Reply #2 on: January 24, 2010, 08:34:14 pm »
70 AMP Is std with no A/C, this bracket has no serpentine tensioner ( two bolts to secure)
Bosch model 028-903-025 G
90 amp is a option with the no A/C, same bracket Non tensioner type bracket ( Two bolts to secure to bracket ) Bosch 028-903-025 P
This type is adjusted by loosing one bolt, these alternators have a spring on the bottom of the alternator to keep the tension on the belt
The below are the A/C type that use a different bracket with a  Tensioner.
90 AMP Bosch  028-903-025 Q
If you have questions let me know?
120 amp   Bosch 028-903-025 S
I have the bracket that attaches to the larger bracket that secures the A/C Compressor.
« Last Edit: January 25, 2010, 01:55:15 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #3January 25, 2010, 10:55:59 am
dyoungen
  • 128
Re: Alternator ( 1.9 70 AMP OR 90 Amp / 120 AMP
« Reply #3 on: January 25, 2010, 10:55:59 am »
I don't know if it would fit but I went from a 75 amp on my 1987 F250 Diesel to a 3G alternator with 130 amps and internal regulator. That is the standard alternator on 1993 or 4 Ford Taurus, I think. Either way, going from 75 amp to 130 made a big differance.
