Author Topic: can't get the fuel shut off out?  (Read 8514 times)
January 21, 2010, 12:21:53 pm
orengutan
  • 27
« on: January 21, 2010, 12:21:53 pm »
hey folks.
I'm diagnosing some weird behavior on my 97 jetta aaz, and part of that invovles replacing the fuel shut off (specifically, it wont turn off when I start it, but it idles fine, so its not a turbo related issue, I expect).
unfortunately, I can't seem to get the dang thing out. any suggestions? I can get a wrench on there, but there's not enough space to do it, and not enough space to get a socket on there. I really dont want to have to undo injector lines to get in there.
advice?
Reply #1January 21, 2010, 05:48:41 pm
Re: can't get the fuel shut off out?
« Reply #1 on: January 21, 2010, 05:48:41 pm »
Try unhooking the power from the stop solenoid when the car is running and then see what happens.
You have to take the lines off to remove the solenoid
Reply #2January 21, 2010, 06:25:34 pm
« Reply #2 on: January 21, 2010, 06:25:34 pm »
When it gets down around -50F my rabbit won't shut off either, just kinda slowly idles down until it's chugging real low. I usually try a couple times and then just let the clutch out. 8)
I've never figured out nor really cared what causes it since I try not to drive it at those temps anyways ;D.
Reply #3January 21, 2010, 06:47:17 pm
Dakotakid
  • 1240
« Reply #3 on: January 21, 2010, 06:47:17 pm »
Wow...at THOSE temps the poor Rabbit is probably afraid he will die if he allows himself to be shut off!!! :(
Reply #4January 22, 2010, 10:52:52 am
orengutan
  • 27
« Reply #4 on: January 22, 2010, 10:52:52 am »
ho hum. I guess I'll have to take the lines off. bugger. I was hoping it to be a minimal effort sort of thing.
I should probably get that bentley, then. no use in winging this one and ***ing it up..
on a sidenote: -50f? sweet baby jebus.
Reply #5January 22, 2010, 11:18:56 am
« Reply #5 on: January 22, 2010, 11:18:56 am »
hey folks.
advice?
dont wanna take the feed lines off? your really friggen lazy.
i could get those lines off in 2 minutes. while taking a nap!!
Reply #6January 22, 2010, 11:20:10 am
orengutan
  • 27
« Reply #6 on: January 22, 2010, 11:20:10 am »
it was cold out! and snowing!
DONT JUDGE ME! :P
Reply #7January 22, 2010, 02:03:26 pm
« Reply #7 on: January 22, 2010, 02:03:26 pm »
Did you try unplugging the stop solenoid while the car was running to see if it stopped? Usually they fail shut, not open.
Reply #8January 22, 2010, 02:06:16 pm
orengutan
  • 27
« Reply #8 on: January 22, 2010, 02:06:16 pm »
its the best guess I've got on my hands.... the car kept consistent idle for a solid ten minutes as I cleaned up (post fuel filter change - my first on a mk3, but Ive done plenty on a mk4 without issue), and then just wouldn't shut off. I tried this twice.
the voltage for the connector is correct too.
any other things I could check other than this? because once I install it, I have to keep this $100 solenoid :)
Reply #9January 24, 2010, 01:46:48 am
  • 3468
    • McScrubbins Body Wash
« Reply #9 on: January 24, 2010, 01:46:48 am »
$100? What the FRICK?
The lines are dead easy to take off
and have you definitely taken the power off of the stop solenoid. You do realize that turning the key OFF cuts power to it and it CLOSES right?
the wire doesn't go to it to tell it to turn off it is there to keep it open to run the car.
i've never even heard of a solenoid failing open.
my bet is that the problem is in your ignition.
Speaking of which, how do you eventually get it to stop? :P
ps. you don't need a bentley to take the lines off. you need a wrench.
« Last Edit: January 24, 2010, 01:48:22 am by Smokey Eddy »
Reply #10January 25, 2010, 10:48:20 am
« Reply #10 on: January 25, 2010, 10:48:20 am »
some fuel solenoids are normally open, and electricity closes the solenoid and shuts it off. its so when the electronics die on the boat, the engine continues to run until 12v is supplied to the fuel solenoid. then you arnet stuck out in the ocean with a dead engine because your wiring job sucked. i think its a better idea anyway. i would rather have 12v to kill my engine, rather than 12v keeping it running. cause your whole 12v system can fail, but the engine will continue to run this way. if you use VW fuel solenoids, no power = no run.
Reply #11January 25, 2010, 02:46:50 pm
Henchman
  • 183
« Reply #11 on: January 25, 2010, 02:46:50 pm »
There should be no need to remove any lines?  I think I did mine last summer with a set of channel locks.
Ian
Reply #12January 25, 2010, 04:04:34 pm
« Reply #12 on: January 25, 2010, 04:04:34 pm »
lines come off with a 17mm IIRC. To get a wrench in there to prevent damaging of the solenoid, the lines should really be removed.
Reply #13January 26, 2010, 09:52:54 am
orengutan
  • 27
« Reply #13 on: January 26, 2010, 09:52:54 am »
I put it in gear and stalled it. how else? :)
I don't think its an ignition issue... there's definitely voltage when its in acc, and no voltage otherwise...
Reply #14January 28, 2010, 03:16:34 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #14 on: January 28, 2010, 03:16:34 pm »
Clucking Bell! That is unfeasably COLD. -45C.
You should see the chaos in the UK with -10c and two inches of snow.  ::)
