Author Topic: Valve grinding: when is it enough?  (Read 7895 times)
January 20, 2010, 02:51:46 am
oris
  • 7
« on: January 20, 2010, 02:51:46 am »
Hi,
First a short introduction:
Allthough this is my first post on this forum, I've been reading quite a lot here for the past year, and have been learning a lot!
My problem:
I'm rebuilding a JR 1.6 TD engine, and at this very moment working on the head.
I've replaced the valve guides an all valves looked great.
So no valves have been replaced and now I've grinded the valves in the valve seat.
But the problem: how well should they seal?
I've filled the ports with white spirit and let it rest for a day.
There was not much leakage, but some, a few milli liter probably.
Will this be tight enough or should I continu grinding until there is no leakage at all?
Thanks!
Reply #1January 20, 2010, 09:06:44 am
Re: Valve grinding: when is it enough?
« Reply #1 on: January 20, 2010, 09:06:44 am »
how perfect do you want them?
Reply #2January 20, 2010, 09:25:34 am
600K
« Reply #2 on: January 20, 2010, 09:25:34 am »
Did you grind the valves and seat or hand lap them?  If you ground them, you should finish with a hand lap to get a final seal.  If you just lapped them, then it should show a complete circle around the valve face.
Reply #3January 20, 2010, 10:25:01 am
oris
  • 7
« Reply #3 on: January 20, 2010, 10:25:01 am »
Well, I would like to use the engine for a long time, and it should be reliable.. :)
I'm assuming that the better the seal, the higher the compression, thus higher MPG and better cold starts, so a leak would be a bad thing.
But how much would the effect of a small leak be on the real life compression?
I hand lapped them, first with a rough compound, followed by a fine compound.
The dirty spots on both the valve seats and the valves themselfs disappeared, and the seats and valves look clean,  but they do leak a tiny bit..
Reply #4January 20, 2010, 01:31:41 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: January 20, 2010, 01:31:41 pm »
Dont go too insane, a continuous ring of matt area all the way round the valve seat. Too narrow, and the valvehead  runs hot, too wide and the contact pressure is lower, possibly allowing combustion pressure to force the valve off the seat. Make sure you wash all traces of the paste away, as it's hungry. But someone else might know better, theories change. The world used to be flat once. ;D
« Last Edit: January 26, 2010, 07:20:56 am by smutts »
Reply #5January 21, 2010, 04:43:24 am
oris
  • 7
« Reply #5 on: January 21, 2010, 04:43:24 am »
Allright!
Just to be sure I've ordered a compression tester,
I'll do a compression test as soon as I've finished working on the head and be able to pre-mount it.
If the numbers are right I know it's ok!
Reply #6January 21, 2010, 05:44:16 am
« Reply #6 on: January 21, 2010, 05:44:16 am »
Edge of intake valve must be 0.5mm    0.02in   or thicker
do not grind stellite coated exhaust vales by machine
Valve seats 45*, contact surface:
2.0mm   0.08in   for intake valve
2.4mm   0.09in   for exhaust valve
use 15* cutter to reduce size
installed gap between valve face and head surface should be less than 1.5mm   0.06in   replace eat, and possibly valve if gap is too large.
or so says my book.
Reply #7January 21, 2010, 09:48:30 am
oris
  • 7
« Reply #7 on: January 21, 2010, 09:48:30 am »
or so says my book.
Thanks, but that's for cutting the contact surface, I didn't cut it by machine,
I only used a grinding compound to lap the surfaces by hand.
Reply #8January 24, 2010, 05:49:03 am
oris
  • 7
« Reply #8 on: January 24, 2010, 05:49:03 am »
The seats (and valves) were all matt.
I've placed the head on the block for a short test (reused the old 3 notch gasket, new one will be 2 notch) and found out that the compression was a bit low, but uniform. (something like 20 Bar, 290PSI, cold engine offcourse: still on a stand)
Could this be caused by the fact that the cylinder walls have been honed and the pistons re-ringed and they should run in first or should I expect it to be caused by ill sealing valves?
Reply #9January 24, 2010, 08:00:30 am
macka
  • 957
« Reply #9 on: January 24, 2010, 08:00:30 am »
The old head gasket for the test is inconclusive as it is pretty much molded to the head before you decked it (you did have it resurfaced right?).The pressure will jump up when you get the rings seated properly. I use dino squeezings for the break in then switch to synthetic oil at the second change interval. Just remember that the oil will be changed twice rather quickly to eliminate metal bits that will be found during the break in. If you can go with a 1 notch head gasket, I'd go that route
Quote from: Vincent Walden
Reply #10January 24, 2010, 09:25:06 am
oris
  • 7
« Reply #10 on: January 24, 2010, 09:25:06 am »
But I might have to remove the head again, will using a new gasket not result in having to throw a new gasket away once I've used it?
Or isn't it a problem (tightening and loosening) if it hadn't heated up?
Nice to hear the compression will go up once the rings have seated
Reply #11January 24, 2010, 07:10:31 pm
macka
  • 957
« Reply #11 on: January 24, 2010, 07:10:31 pm »
the old gasket will be different, especially when you go from a 3 to a 2 holer compression wise. WHy would you need to pull the head again? If you are doing lots of stuff, just wait until you are ready to button it up for good to do a compression test. I'd say with those numbers on a 3 holer that is used you should see way better numbers with the new 2 holer once you are buttoned up for running. Don't waste your time this early with a compression test, as it really isn't close to a final proper number. Get the valves sorted out and be ready after its been ran to test. Right now you are distracting yourself with unnecessary self made worries.
Reply #12January 25, 2010, 10:32:32 am
« Reply #12 on: January 25, 2010, 10:32:32 am »
SOOOOOOOOOOOOOOO many people have this problem on this forum. i occasionally do too, but then when i have all the self made worries, usually something goes wrong. if i dont worry about anything, things go as planned.
Reply #13January 26, 2010, 12:46:19 am
oris
  • 7
« Reply #13 on: January 26, 2010, 12:46:19 am »
I guess you're right, it hard to determine what's right and what's wrong if you haven't got a lot of experience, asking more experienced people can help in those occasions :)
Reply #14January 26, 2010, 07:24:58 am
smutts
  • 720
« Reply #14 on: January 26, 2010, 07:24:58 am »
I guess you're right, it hard to determine what's right and what's wrong if you haven't got a lot of experience, asking more experienced people can help in those occasions Smiley
As the old saying goes, "We learn by our mistakes."  So why am I not a genius, with lots of broken engines? ;D
« Last Edit: January 26, 2010, 07:27:34 am by smutts »
