Author Topic: 1.6 Questions  (Read 3770 times)
November 11, 2005, 12:12:30 pm
T-hane
  • 15
1.6 Questions
« on: November 11, 2005, 12:12:30 pm »
I have been recently been reading all the post on diesel mods and it had inspired me to buy a 1.6.  prior to the I have had a 90 jetta 8v auto which I converted into an 2.0 16v std running digi 2.  And now I want to convert it to a 1.6 turbo the donor car the I have bought is a 86 1.6 turbo with a trans code AGS.  im not a 100% sure where to find the engine code for this car but I assume it is a mf the thing that I can read on the turbo is 16w kkk 5324 So im assuming that it is a k24.  The car runs good it has 340km on the clock and looks as it had been rebuilt as the block is painted green and very clean other then the valve cover leaking.  I plan to pull this engine out and replace the valve cover gasket and the oil pan as well as new glow plugs and the pump mod.  I will add to the car full 3" exhaust and a pyrometer and boost gauge.  I would like to increase the boost to as much as a non-intercooled engine will handle.  I would like to put new injectors into the car and set the pump timing as well I have not seen many threads on increasing the boost in these cars so I am not sure how to do it.  and so far this is the info I have colleted for the pump mod.  if anyone can help me with ideas on how to increase boost and others mods I would appreciate it.  And with easy mods do you feel that my car will be faster then the 16v.  Thanks
I will summarize the steps to do this mod yourself below.
The modification can be done with the pump installed on the motor (and steps below will assume this is how you're doing it), but it will be easier and less risky if it is done with the pump removed from the motor. There will be less risk of some sensitive part being dropped and lost, or diesel fuel draining all over your coolant hoses when the pump is opened up etc.
Disclaimer - perform these steps at your own risk - putting the pump back together wrong can result in a very difficult to fix problem and even severe engine damage! That said, on to the steps...
Before removing anything than opens up to diesel fuel, clean off all the external dirt first. Spray solvent, compressed air, paper towels, etc. Don't let any dirt get inside the injection pump or into the areas where there is fuel. If the engine is particularly nasty, pressure wash the area first. Work in a clean environment - inside preferably but if outside, should be when there is no dust or wind.
1. Disconnect LDA boost tube (small rubber hose.) Pop off accelerator pedal connection to ballstud on input throttle shaft on pump. Remove two 10mm bolts holding throttle pedal bracket to top of pump and remove throttle pedal bracket from pump top. Mark position of throttle arm on shaft (in particular the orientation of the line on the top of the stud in relation to the throttle arm.) Remove the 10mm nut on the top throttle shaft and remove the throttle arm and the return springs. Keep all the pieces in order on how they are put together, so they can be reassembled later.
2. Prepare governor cover for removal as follows: Crack open one of the small fuel return hoses and allow air to bleed into the fuel return line. Remove the fuel return banjo bolt and pull away the fuel return banjo fitting, and wrap a rag around the banjo fitting to keep dirt from getting in and set it aside. Set up paper towels to catch any diesel that drains out of the pump - keep it off the radiator hoses (diesel on radiator hoses must be thoroughly cleaned off as it will attack the rubber over time.) Set aside in a clean spot the copper crush washers and banjo bolt for the fuel return fitting for later reinstallation. Everything should now be disconnected from the governor top.
Photo of a turbo-diesel pump ready for governor cover removal, courtesy of Mark, AKA dieselpower:
3. Remove governor cover. It is held on by 4 allen-head bolts. I recommend not disturbing the fuel screw. Some diesel will probably spill as the governor cover is cracked open - I recommend catching the spilled diesel with rags or paper towels before they touch the coolant hoses. After removing the allen head bolts completely, the governor cover will only be held on by the governor mechanism. Sometimes it can be easily disconnected from the tensioning lever, but only if the orientation of the governor is right (there is a slot it fits though, but only if it is rotated to the proper angle.) What I would recommend is pushing the throttle lever shaft down through the governor cover as you lift the governor cover off of the rest of the pump, so the whole governor mechanism including the throttle input shaft is left behind attached and on top of the pump. Be careful not to bend or otherwise damage the governor when doing this! Leave diesel filled up to the brim in the main pump cavity to make the pump easier to start back up. After the governor cover is removed, set it aside in a clean spot.
Photo (courtesy Mark / dieselpower) of what the pump looks like with governor cover removed:
4. Remove the governor assembly from the tensioning lever. You will find the governor assembly when rotated correctly will come off the tensioning lever through a notch. You should now have the governor assembly removed and can work on it to perform the modification.
Photo (courtesy Mark / dieselpower) of throttle shaft / governor assembly removed from pump:
5. Modify the governor to eliminate the intermediate spring as follows. Measure the travel of the intermediate spring by pulling on the ends of the governor capsule. (The intermediate spring is the first one of the two inside the capsule that compresses.) You can see the intermediate spring seats are wide things that only allow a small amount of spring travel:
Find a shim that will take up this movement when inserted between the intermediate spring seats at the area where they are closest to each other. 3/16" aluminum pop rivet backing washers are of suitable ID and OD, but you'll need to arrive at the right overall shim thickness (possibly re-using the original shims between the intermediate spring seats if present and if needed.) The idea behind the shims is to fix the intermediate spring solidly in the extended position, so it can be removed. Insert the shims by disassembling the governor capsule as follows: First remove the circlip on the end of the idling spring. Remove idling spring and it's spring seats, and set them aside in proper order so they can be later reassembled. Press the outer intermediate spring seat into the governor capsule and lift it up and away of the pivoting structure that is riveted to the throttle arm. Then slip off the outer intermediate spring seat and the intermediate spring and insert shims needed to disable the intermediate spring. Slip the outer intermediate spring seat back over the shaft, and compress it and reinstall it into the governor capsule bracket that is riveted to the throttle shaft. Test the springs to make sure they are not loose in the bracket. Reassemble the idling spring and their seats and circlip.
6. Insert the governor/throttle shaft mechanism back onto the tensioning lever, engaging the slotted area of the shaft through the slotted opening of the tensioning lever. Rotate it so it is engaged securely when installed.
7. With the throttle shaft in the correct orientation, lubricate the throttle shaft o-ring with clean diesel fuel and press the governor cover over the throttle shaft. Push the governor cover down onto the pump and slide the cover towards the high pressure fuel output end to engage the fueling adjustment screw and align the governor cover with the bolt holes. Reinstall the four allen head bolts and snug them down (to I'd say about 7.5 ft-lbs.)
8. Put everything else back in reverse order from how it was removed. Duplicate the original orientation of the throttle shaft on the arm that was recorded in step one by getting the throttle arm onto the correct spline position. Fire the engine up and make sure that there are no newfound diesel leaks - if there are any fix 'em before they leak diesel all over the place. That's it you're done! Enjoy your newfound horsepower and powerband
1.
1.
1. It's the o-ring at the top of the throttle shaft that makes the resistance when pressing it into the governor cover bore. Clean the bore with solvent like brake parts cleaner. Lubricate it as well as the o-ring at the top of the shaft with diesel (or maybe even try something a little slipplier, like motor oil.) Just don't press it in dry! To get the throttle shaft started into the bore, I usually put my finger underneath the throttle shaft to get it started and press it in that way as far as I can keep my finger there. When the cover is down so far that I need to remove my finger from underneath, I haven't had a problem just pressing it down lightly the rest of the way. The cylindrical flyweight holder should be stout enough to withstand the needed pressure, just don't force anything! After the cover is pushed down all the way and the four bolts are installed, grab the threaded top of the throttle shaft and pull it all the way up, or install the throttle arm and tighten the nut to pull the shaft all the way up. Just make sure to get the throttle arm oriented correctly, which can be a bit tricky while holding against those springs.
2. The quickest way is as I've described above: set the governor cover down a little bit towards the pulley end, so the end of one of the governor levers is at the side of the end of the fuel adjust screw, and then it gets tensioned when the governor cover is slide away from the pulley end until the hollow dowel pin engages and bolts can be installed.
If you are having problems with this method, there is another way, which involved completely or nearly removing the fuel adjusting screw. If you do this, be sure to measure it's position before you remove it and/or count turns, so it can be put back in exactly in the same position as it was originally - to the nearest fraction of a turn. If you forget or mess up it's position, you have a real risk of making your pump really hard to start or setup so it will melt your engine down shortly after it starts.
3. Yes.
4. You've got it... The mod maintains full fueling to higher RPMs, whereas when it was stock the fueling would gradually drop over an RPM range before the main revv limiter kicked in.
With the governor mod, the car will feel the same as it did before in all driving conditions, until the pedal is floored and the revvs climb up, at which point the car will go like a scalded cat all the way until it hits the main revv limiter, instead like a wheezing its way up there like it originally did.
1.
