Author Topic: WTB: AAZ banjo fitting for turbo oil block return (complete)  (Read 3815 times)
January 19, 2010, 09:56:59 am
87octane
« on: January 19, 2010, 09:56:59 am »
I need both the drilled bolt that threads into the block and the matching banjo fitting for the turbo oil return line. I've got  a pipe plug in mine now with a messy dripping return into the oil pan, badness.
PM me with whatever you've got. Thanks. Ric.
Reply #1January 19, 2010, 11:03:41 am
GEE-BEE
  • 1604
Re: WTB: AAZ banjo fitting for turbo oil block return (complete)
« Reply #1 on: January 19, 2010, 11:03:41 am »
I HAVE A NEW BANJO BOLT AND TWO CRUSH WASHERS 12.50 VIA MAIL
I HAVE A EXTRA K03 HOSE LINE OIL RETURN ( FREE )
THE BOLT SCREWS THRU THE HOSE FITTING INTO THE BLOCK
PAYPAL : [email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 21, 2010, 01:30:03 pm
GEE-BEE
  • 1604
« Reply #2 on: January 21, 2010, 01:30:03 pm »
SHIPPING TODAY !
Giles Pump OHC
MK1 JETTA DASH
Reply #3January 22, 2010, 05:13:46 am
stewardc
« Reply #3 on: January 22, 2010, 05:13:46 am »
I actually replaced the troublesome banjo fitting with a simple JIC flared fitting, then had a local hydraulic shop make a custom hose.
