Author Topic: G-Teched my 1.6TD - Part 2  (Read 151471 times)
Reply #255May 23, 2006, 07:20:33 pm
zagarus
  • 619
« Reply #255 on: May 23, 2006, 07:20:33 pm »
Quote from: malone
edit: I'd also like to note that during some hard (est. 170-190bhp) runs,
is that what your 1.6td is running?!! :shock:
Reply #256May 23, 2006, 08:40:46 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #256 on: May 23, 2006, 08:40:46 pm »
Those are estimated numbers, I didn't have the chance to go on a dyno, but I'm confident in these numbers after being compared against a MK3 Golf VR6 (by racing & comparing consistent Gtech results). Anyway, it was real fast.. enough for me to want to keep the engine :) I'm selling my 3 diesel vehicles, this black MK3 Golf, the red 1991 Jetta 1.6TD, and the light blue 1984 Rabbit.
There will be no room to store these cars other than the TDI I'll be getting, but after I'm settled in a while after moving, I'll find a clean chassis to put the IDI engine back in. Maybe a MK1 or MK2 instead of another MK3.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #257May 23, 2006, 08:54:51 pm
  • 1156
« Reply #257 on: May 23, 2006, 08:54:51 pm »
Great to get an update and hear about the job and plans you have for the future.  Bummer about the cooling issue.  Good luck on house-hunting, a garage was more important than square footage when I was searching!  Probably similar for you...
Thanks.. $250,000 ($223,000 USD) will get me a 900 to 1,200 sqft condo or apartment in Langley, BC, which is a 1 hour 15 minute drive away from my work in Vancouver. Detached homes with decent garages are at LEAST $310,000 USD ea. in Langley. Homes in Vancouver are not cheaper.
I can find a townhome with a garage for $223k USD, but it's a very narrow 1-car garage. No elbow room. Lower mainland BC likely has the highest housing costs in Canada :roll: I have a few months to do house-hounting, though.
I could consider renting a small warehouse with a few people to store full-time project cars in, but even that may be expensive.. we'll have to see.
On the crankshaft, I am leaning towards polishing, shot-peening, and cryoing, in that order.  What experiences do people have with custom rods on high output VW Diesels?  I have only talked to VW Gas guys and those rods hold up with just minor modding to a lot of power, but I imagine the BMEPs are much lower.  Dunno, just wondering.
Keep us informed, you are a real inspiration.  Any more information on the compound setup?  I am leaning heavily towards that myself.
Other than what I've posted before, I have no further information on the compound setup. The turbos I mentioned may not be finalized... finding the best sized compound turbos on paper is tricky.
Your order of crankshaft prepping sounds good. I'm curious as to know how custom rods affect BMEP.
Simon Cooper "tdi rs" used custom rods in his ~220whp mechanical TDI after bending stock rods. He did not mention any adverse effects from switching to custom rods.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #258May 23, 2006, 09:51:35 pm
zagarus
  • 619
« Reply #258 on: May 23, 2006, 09:51:35 pm »
okay so 170-190 hp, do i even want to know where the torque is at?! :idea:
Reply #259May 23, 2006, 10:08:03 pm
  • 1156
« Reply #259 on: May 23, 2006, 10:08:03 pm »
Not much, around 190-210 ft-lbs to be conservative. My TD's torque peaked at approx. 4,000 RPM unlike a typical TDI at 2,100 to 2,500 RPM. Estimated 140hp at 4,000 RPM, climbing higher until the fuel cut-off point at 5,250 RPM.
I like the closer torque : HP ratio because it means I do not need to make impractical amounts of torque just to have adequate HP. My next TD setup may have torque peak during higher RPM. It'd be interesting to see if I can hold 250lb-ft at around 5,252 RPM for 250hp, but I'll still push the engine as far as it can go.
If my ~200 ft-lbs torque peaks at 2,500 RPM instead of 4,000 RPM and then quickly drops off (just like a TDI), I'd likely only have roughly 120hp. Depends on the rest of the torque curve.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #260May 23, 2006, 10:56:59 pm
zagarus
  • 619
« Reply #260 on: May 23, 2006, 10:56:59 pm »
how much time and money has been put in to get these numbers?  what do you think i could achieve as a semi serious diesel tuner?  110hp a possibility?
Reply #261May 24, 2006, 03:36:55 pm
  • 1156
« Reply #261 on: May 24, 2006, 03:36:55 pm »
Major components are as follows.. prices are in CAD:
Fuel pump upgrade: $950
GT20 turbo and exhaust manifold, both cermachromed: Roughly $1,000
Air/water intercooler conversion based on brand new OEM TDI intercooler: Approx. $500 total
Autometer gauge set (including oil temp, oil pressure, volts that I already bought years ago): $500 after discount.
Damaged 1.9L AAZ head: $300.
4-puck clutch, pressure plate, and lightened flywheel: Roughly $300 combined.
The PD130 intake manifold is valued at approx. $175
That's $3,725 total
Starting with a wrecked 1.6TD engine and including upgrades, including complete 1.9TD head rebuild, the costs were probably $4,000. Includes $265 USD for Raceware head studs, custom camshaft, etc.
Throw in $200 in misc. stuff, like headgasket, new timing belt, oil, fuel filter, etc.
That's a grand total of $7,925 CAD. Still a rough estimate. Seems like a hefty price tag. Also I was nowhere near the maximum power potential due to lack of intercooling, lack of fuel during high RPM, etc. I haven't bent my shot-peened OEM rods yet. Building on the stock block may suck in another $2,500 mainly due to AAZ pistons, coating, custom rods and crank work (not cheap). 2 new turbochargers for compound turbocharging is not going to be cheap either. I'm fortunate enough to receive sponsorship by Superior Fuel Injection for upgrading my fuel pump to a Stage 5 or so next time. I've only put 10,000km on my stage 4 fuel pump and I still need more fuel!
$8k CAD so far seems like a lot, but including the value of the vehicle shell it's not more than $12,000 CAD... which is still half the price of a typical low km 90HP MKIV TDI vehicle.
The MKV Jetta TDI will cost me around $30,000 CAD after taxes and I'm back to square one with 100HP :roll: but it's intended to be a warranteed daily driver (and my chip demo vehicle) so my IDI will be an evening or weekend racer/driver.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #262May 24, 2006, 03:48:23 pm
  • 1156
« Reply #262 on: May 24, 2006, 03:48:23 pm »
Quote from: zagarus
To answer your second question, start by:
1) installing an intercooler.
2) installing a boost gauge and a pyrometer (tap in thermocouple pre-turbine).
3) upping your boost to 24 PSI or so if you have a T3 or K24.
4) upgrading your fuel pump and setting its timing to 1.05mm. Doing the fuel governor mod and turning up fuel IQ is decent, but there's still more than that.. i.e. upgrading camplate to 1.9. That should be enough for 110HP.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #263May 24, 2006, 05:13:32 pm
zagarus
  • 619
« Reply #263 on: May 24, 2006, 05:13:32 pm »
sweet!  i plan on getting intercooler and exhaust done next month, the intercooler is 21.75x6.5x2.5 and is 300cad from kinetic motorsport.  The exhaust i plan on getting done at passenger performance.  So thats a good start. Plus ill be getting a manual boost controller and uping the boost.  Just need to figure out when to do the egt gauge install.
Reply #264May 24, 2006, 05:59:28 pm
  • 1156
« Reply #264 on: May 24, 2006, 05:59:28 pm »
Good idea on the exhaust upgrade, I forgot about that. Maybe PP can install the EGT thermocouple pre-turbo when you go in for a downpipe...
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #265May 24, 2006, 07:26:06 pm
zagarus
  • 619
« Reply #265 on: May 24, 2006, 07:26:06 pm »
thats what im hoping will happen, heck maybe ill even get them to install my intercooler while im at it...Intercooler, 2.5 exhaust, egt gauge!! Damn i'd be set then!
Reply #266May 24, 2006, 09:06:53 pm
935racer
« Reply #266 on: May 24, 2006, 09:06:53 pm »
Yep I can definately do the whole works for you, aftercooler installs and plumbing are my favorite.
Reply #267May 24, 2006, 09:15:51 pm
zagarus
  • 619
« Reply #267 on: May 24, 2006, 09:15:51 pm »
so whats that gonna cost me  :P ?
Reply #268May 24, 2006, 09:53:40 pm
935racer
« Reply #268 on: May 24, 2006, 09:53:40 pm »
Downpipe, full mandrel bent exhaust, aftercooler piping, silcone adapters and  boost clamps, egt install... Probably want to make a custom air intake and put a cone filter on there at the same time, Gonna be around $1200.
Reply #269May 24, 2006, 10:25:17 pm
zagarus
  • 619
« Reply #269 on: May 24, 2006, 10:25:17 pm »
thats it!!!! *** son you have a customer...next month that is, gotta make the money first  :D   Ya i know which exhaust ill probably be getting, i know the intercooler, so ya sweet.
