Author Topic: Low temp thermostat affect milage?  (Read 5344 times)
June 28, 2004, 10:08:43 pm
Cheesetoast
  • 285
« on: June 28, 2004, 10:08:43 pm »
would putting a low temp thermostat in a 93 vw golf 1.9td affect the fuel economy positively or negatively?  I think mine has one in it, temp stays at 75 most of the time, should i switch to a regular one?
Reply #1June 29, 2004, 07:16:52 am
VWRacer
  • 649
« Reply #1 on: June 29, 2004, 07:16:52 am »
To me 75 sounds too low. Both my '85 1.6TD and my '02 Golf TDi run at 95. Folks typically install a 75 thinking it will lower overall engine coolant temp, but it rarely works that simply. I'd try a 95. If the engine runs too hot, fix the real reason -- don't install a lower thermostat as a stop-gap.
My 2-cents (Canadian... :wink: )
Stan
C-Sports Racer
Reply #2June 29, 2004, 10:19:45 am
Cheesetoast
  • 285
« Reply #2 on: June 29, 2004, 10:19:45 am »
it's always been running that low since i got it.  is it affecting my fuel economy or anything?  i could go buy a regular one and switch, but should i bother?
Reply #3June 29, 2004, 10:26:37 am
VWRacer
  • 649
« Reply #3 on: June 29, 2004, 10:26:37 am »
I doubt it make a great deal of difference to fuel economy in a daily driver, though it will make a very small dent in the economy and power of the engine. Whether you could see it even in back-to-back testing in the real world is problematical, though.
Stan
C-Sports Racer
Reply #4June 29, 2004, 12:16:21 pm
farkman
  • 172
« Reply #4 on: June 29, 2004, 12:16:21 pm »
Cheesetoast
My 94 Golf does the same thing. The gauge only moves between 70-80 degrees. But I think that this isn't the actual temperature of the coolant in the engine. I think the reading is  from somewhere else like the radiator because I have the cooling fan schematics and it says that the fan turns on at 95 degrees. When I park in the garage and shut the engine off, the cooling fans are running even though the gauge is at about 75-80. So if the cooling fans turn on when you shut the engine off I think your car is running normally.
Take care.
