piston ring gap
Topic: piston ring gap (Read 3061 times)
October 27, 2005, 09:39:03 am
mattmey
User+
piston ring gap
October 27, 2005, 09:39:03 am »
Just got freshly bored block back and starting to put it back together.
Was woundering if the ring gap on Goetz pistons are good enough to run out of the box or if you have to file the ends. If I have to file the rings what is the recommonded gap?
Thanks
October 27, 2005, 01:20:26 pm
Mark(The Miser)UK
piston ring gap
October 27, 2005, 01:20:26 pm »
0.3 TO 0.5MM WEAR LIMIT 1.0mm; or is that just for the old 1.5? :?:
Mark-The-Miser-UK
October 27, 2005, 01:41:17 pm
VWRacer
Ring Gaps for the 1.6TD Engine
October 27, 2005, 01:41:17 pm »
My Bentley's calls for the upper and low compression rings to be gapped at .3-.5mm (.012-.020"), and for the oil scraper ring to be gapped at .25-.40mm (.010-.016"). Wear limit for all rings is 1mm.
Stan
C-Sports Racer
October 27, 2005, 05:00:45 pm
mattmey
User+
piston ring gap
October 27, 2005, 05:00:45 pm »
Pistons and rings are brand new so I don't have to worry about wear. Hopefully not for awhile atleast.
Thanks for the specs
piston ring gap
