Author Topic: Running NA 14 injectors in N/A  (Read 4643 times)
January 16, 2010, 09:00:49 am
Dakotakid
  • 1240
« on: January 16, 2010, 09:00:49 am »
What is your best guess (or experience) on setting the timing using turbo injectors in an N/A application?
Reply #1January 16, 2010, 09:13:00 am
Re: Running NA 14 injectors in N/A
« Reply #1 on: January 16, 2010, 09:13:00 am »
The general concensis seems to be to use the timing setting that matches the injector breaking pressure.
So if you use 135bar (NA) injectors use the NA timing settings (0.90-1.00ish)
If you use 150/155bar (turbo) injectors use the turbo timing settings (0.95-1.05ish)
If you (or someone like Giles) has modified the pump to have lots of additional dynamic advance then the NA settings will work well even with 155bar injectors.
Reply #2January 16, 2010, 04:57:50 pm
Dakotakid
  • 1240
« Reply #2 on: January 16, 2010, 04:57:50 pm »
Thank you. Sorry if it has been discussed before.
I just bought rebuilt 155's and there is probably going to be a delay getting the turbo engine up and running. I wanted to see if these work in the meantime.
