Author Topic: Cold start lever broke !!  (Read 4791 times)
January 16, 2010, 06:11:11 am
aadonline
« on: January 16, 2010, 06:11:11 am »
Hi guys:
I broke the handle of the cold start lever (AAZ motor). Now the lever is all the way out. Is it ok to run the way it is? will it hurt my pump. I hate to push it back in. If I cant get it out its hard to start :-[
Thanks
Reply #1January 16, 2010, 06:17:35 am
Re: Cold start lever broke !!
« Reply #1 on: January 16, 2010, 06:17:35 am »
It depends on the style of driving you do. If you idle a lot then eventually you will seriously damage your pump. It won't happen overnight though. If you are mostly above 1500-2000 RPM then you shouldn't have any adverse effects.
Reply #2January 16, 2010, 07:11:51 am
Wayland
  • 364
« Reply #2 on: January 16, 2010, 07:11:51 am »
Can you clamp vise-grips onto the broken stub so you can still move the cable in and out?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #3January 16, 2010, 07:48:39 am
54321chris
« Reply #3 on: January 16, 2010, 07:48:39 am »
Can you get to the fitting on the pump where the cable connects?  I don't have a lever on my car, I just use a screwdriver to move the lever on the pump.  But I don't know if the AAZ pump is the same as my 1.6 pump.
Reply #4January 16, 2010, 08:55:56 am
Kworth 2007
  • 36
« Reply #4 on: January 16, 2010, 08:55:56 am »
Hi
the dealer can order that handle in
the handle and the plastic locknut thing was under $10
any old pieces to take in with you ,they bring up a photo of all the parts.
take a few days to order in.   I used pilers for months it SUCKS!
Cory
96 Jetta 1.9L (AAZ) 5spd (300KM)
80 F150 5.8L(160KM)
99 Escort 2.0L 5 spd (190KM)
Reply #5January 16, 2010, 09:46:18 am
aadonline
« Reply #5 on: January 16, 2010, 09:46:18 am »
Thanks guys !
I am using vice grip for now.
Reply #6January 16, 2010, 02:13:43 pm
Henchman
  • 183
« Reply #6 on: January 16, 2010, 02:13:43 pm »
Mine has been broken since I bought it over 2 years ago.  I kept it pushed in and just adjusted the base rpm to about 950rmp.  Works for me.
Ian
Reply #7January 16, 2010, 05:56:35 pm
Kworth 2007
  • 36
« Reply #7 on: January 16, 2010, 05:56:35 pm »
Hi Henchman
After the HUGE repair bill if be paying for me car, a small handle broken on cold start will be fix, not to screw up the rebuilt pump.  That the way I work. $ 10 item on a $ 4000 overhaul, to advance the timing.
Cory
"E brake turns ROCK!,  find a empty lot with a large slippery area try it U like it.  YA"
80 F150 5.8L(160KM)
Reply #8January 16, 2010, 07:21:16 pm
« Reply #8 on: January 16, 2010, 07:21:16 pm »
Damn right they do :)
Reply #9January 16, 2010, 07:24:05 pm
« Reply #9 on: January 16, 2010, 07:24:05 pm »
just put some Mc Donalds or Burgerking trays under your rear tires and pull the e brake, then drive around the big parking lot drifting like no other.
Reply #10January 16, 2010, 07:25:10 pm
« Reply #10 on: January 16, 2010, 07:25:10 pm »
DUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUDEEEE!!!!!!!!! that sounds AWESOMEE How does it handle!?
Reply #11January 16, 2010, 09:44:03 pm
mystery3
  • 774
« Reply #11 on: January 16, 2010, 09:44:03 pm »
You can also do this on wet grass if you live someplace with no ice.
It handles crazy loose, pretty much exactly how you think it would handle.
Reply #12January 17, 2010, 05:15:07 am
macka
  • 957
« Reply #12 on: January 17, 2010, 05:15:07 am »
That sounds willllllldddddddddddd  ;D
Quote from: Vincent Walden
Reply #13January 17, 2010, 08:18:06 am
« Reply #13 on: January 17, 2010, 08:18:06 am »
except the bad thing about wet grass is the fact that its wet grass, the tires have a hard time grabbing it.
on a sidenote, when my 5000 was still running, i could go out in my field, and its pretty big. bout a half mile wide and mile long. many a day during the summer i would go out there and just drift. i kept it sideways for over a mile once, but it was back, and forth, not just completely sideways un touched for a mile. either way, lots of fun to be had with FWD cars.
and these cars pretty much handle like they have swivel casters on the rear axle if you put something slick under there. (grass, food trays, whatever you can think of.)
Reply #14January 17, 2010, 02:18:31 pm
Dieselumbrado
  • 19
« Reply #14 on: January 17, 2010, 02:18:31 pm »
I'm not using the cold start, because is leaking, and I don't want to disturb it, to avoid leaking more, sometimes doesn't leak at all, more when the engine is cold and idling.
Talking about that, am I doing any harm to the engine starting it (when is very cold) without using the cold start?
Btw the car is a 82 Rabbit...
Thanks
