Author Topic: "91 Diesel Thermostat R&R  (Read 5765 times)
January 12, 2010, 10:13:59 pm
thomas m
  • 144
« on: January 12, 2010, 10:13:59 pm »
Does anyone have a link to some good photos of changing out a thermostat on a '91 diesel with power steering??? That PS pump is in the way for sure.
Thanks
Thomas, Original owner since new:
1991 MK2 Jetta Non-turbo 1.6 diesel, Engine Code ME, 5 speed 020 AWY 04120 transmission, Hydraulic Lifters,
320,000 miles
LOOKING FOR REBUILD OPTIONS IN PORTLAND, OR OR ON THE WEST COAST
Reply #1January 13, 2010, 10:00:10 am
Re: "91 Diesel Thermostat R&R
« Reply #1 on: January 13, 2010, 10:00:10 am »
yeah remove the power steering pump but make sure to keep the lines attached. There will be 5 bolts you need to remove. 2 are vertical and go into the block parallel to the oil pan, 2 are behind the crank pulley and the other one is below the AC (or alt) and runs horizontal, parallel to the crankshaft.
Once that's removed it's just the 2 bolts for the thermostat housing and you're golden.
If you have a look under the car you should be able to see what I am talking about
