Author Topic: This cold weather is killing my car....  (Read 4926 times)
January 08, 2010, 04:14:42 pm
playit
  • 16
« on: January 08, 2010, 04:14:42 pm »
Ok...maybe its not killing my car, but it dosent like it!
Btw I live in florida so I'm not use to 15 degrees in the morning.
When I crank up my car from a cold start it leaks out oil right above the oil filter, but once it warms up it stops leaking. It started doing this when the weather turned cold....or maybe its just a coincidence.
I'm running rotella synthetic 5w40 with a wix filter (I have a mann filter on the way)
91 ecodiesel.
Reply #1January 08, 2010, 04:57:56 pm
wolf_walker
  • 1205
Re: This cold weather is killing my car....
« Reply #1 on: January 08, 2010, 04:57:56 pm »
Oil pressure is very high when cold.  Is it leaking from the vent hose to the vacuum pump(or blockoff plate if you don't have that).
Or more likely the pedestal the oil filter mounts on.  It's an easy gasket to replace, or snug up the bolts, if so.
If that's the only leak you have you are blessed, heh..
Mentat Text Two
Reply #2January 08, 2010, 05:46:07 pm
playit
  • 16
« Reply #2 on: January 08, 2010, 05:46:07 pm »
Its leaking from the pedestal. I had every seal in that motor replaced a year ago with the timing belt, water pump, head gasket, rear main (when I did the clutch) and its still a wet motor lol. But its leaking a good bit from the oil filter pedestal, all the other leaks...well I wouldnt call them leaks more like motor sweat.
Thanks for the reply.
Tim B.
Reply #3January 08, 2010, 05:52:17 pm
rallydiesel
  • 1880
« Reply #3 on: January 08, 2010, 05:52:17 pm »
Aside from switching the gasket or tightening the bolts a bit more, you could try switching to 15w40 Rotella. That's what I run and it'll start at -45C when it's plugged in, -25C when not. You really don't need the Rotella 5w40 although it is a great oil.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4January 08, 2010, 06:42:34 pm
« Reply #4 on: January 08, 2010, 06:42:34 pm »
15W40 would cause even higher cold oil pressures then 5w40 wouldn't it?
Reply #5January 08, 2010, 07:25:18 pm
rallydiesel
  • 1880
« Reply #5 on: January 08, 2010, 07:25:18 pm »
Oh yeah, I didn't read the first post carefully enough. Stops leaking once it warms up. Well, at least you know your engine is actually in good shape as far as the bearings and lifters are concerned.
Reply #6January 08, 2010, 09:22:48 pm
wolf_walker
  • 1205
« Reply #6 on: January 08, 2010, 09:22:48 pm »
Yeah I did all the seals and gaskets on mine when it was out this last time too, 3/4 of em weep.  Just a VW thing I guess, never had another motor leak like this.  Damn mercedes is 36 years old and has only one or two small traces.  Maybe it'll keep something from rusting.
Mentat Text Two
Reply #7January 09, 2010, 07:42:22 am
playit
  • 16
« Reply #7 on: January 09, 2010, 07:42:22 am »
yeah, my dad has a 93 5 cyl bens (odometer stoped at 271k 3 years ago) no leaks. my grandpa has a 85 5cyl 193k miles and no leaks. and mine only has 156k and its allways wet, go figure ::)
I guess I'll check those bolts and hunt me a gasket.
Thanks for your help guys.
Tim B.
Reply #8January 09, 2010, 07:57:49 am
playit
  • 16
« Reply #8 on: January 09, 2010, 07:57:49 am »
Reply #9January 09, 2010, 08:13:46 am
« Reply #9 on: January 09, 2010, 08:13:46 am »
Yes that is it
Reply #10January 09, 2010, 10:15:58 am
playit
  • 16
« Reply #10 on: January 09, 2010, 10:15:58 am »
thanks
Reply #11January 09, 2010, 11:54:22 am
rabbitman
  • 2788
« Reply #11 on: January 09, 2010, 11:54:22 am »
I can start up at 0F with delo 10w-30 and it doesn't puke oil out.....at least right there ::)
Is the oil filter tight?
