Author Topic: governor mod, no throttle...  (Read 3201 times)
January 08, 2010, 01:43:45 pm
54321chris
« on: January 08, 2010, 01:43:45 pm »
I did the governor mod recently and now my throttle isn't working.  I'm guessing the splines on the throttle shaft aren't down far enough.  Is there a trick to make sure I get it right?
« Last Edit: January 08, 2010, 08:26:06 pm by 54321chris »
Reply #1January 09, 2010, 08:41:42 am
Re: governor mod, no throttle...
« Reply #1 on: January 09, 2010, 08:41:42 am »
you have it off a spline too far one way or the other. starts up real nice and all it does is idle? i did this once. just moved it one spline and now it rips.
Reply #2January 10, 2010, 01:15:35 pm
54321chris
« Reply #2 on: January 10, 2010, 01:15:35 pm »
That's exactly right.  I'll try and move it over in a bit.
Reply #3January 11, 2010, 04:52:16 am
regcheeseman
  • 714
« Reply #3 on: January 11, 2010, 04:52:16 am »
Yep. Mark it all up carefully before dismantling!
Don't worry, I and many others have made the same mistake  :-[
Reply #4January 11, 2010, 05:36:28 am
54321chris
« Reply #4 on: January 11, 2010, 05:36:28 am »
Oops...  :(
Reply #5January 11, 2010, 08:55:20 am
« Reply #5 on: January 11, 2010, 08:55:20 am »
lots of people do that on their first gov mod.
Reply #6January 12, 2010, 04:58:01 am
54321chris
« Reply #6 on: January 12, 2010, 04:58:01 am »
Could I possibly move it over while the engine is running to make sure I get it right without having to do this several times?
Reply #7January 12, 2010, 05:29:53 am
« Reply #7 on: January 12, 2010, 05:29:53 am »
I wouldn't . With the gov. assembly spinning it will be weighted and hard to move it nice and easy...or at all.
Reply #8January 12, 2010, 05:18:38 pm
54321chris
« Reply #8 on: January 12, 2010, 05:18:38 pm »
Thanks to all for the input.  I now have a working throttle!  IC piping, a seat, and I'll have a car!  8)
Reply #9January 13, 2010, 03:16:33 pm
54321chris
« Reply #9 on: January 13, 2010, 03:16:33 pm »
Just to finish the story for those watching, I turned the throttle shaft CCW until it met resistance, then installed the springs and arms.  Perfect.
