Author Topic: Transmission Mount switch  (Read 1928 times)
January 06, 2010, 01:54:04 pm
harchar626
  • 4
« on: January 06, 2010, 01:54:04 pm »
 there are so many abbreviations used by people posting I need a separate window open to google the terms.  i've turned enough wrenches to have the confidence and basic understanding for "major projects" but now i need real help!
 I picked up a 84 diesel Jetta for $100.00 and drove it home.  the body is in wretched shape and an eye sore for the rest of the block.  i got the engine out and am ready to put in into a 92 Golf. i got the Golf for $200.00 and it's in great shape but had a a gas engine. (which i also drove home after purchase)  both engines are out and my first hurdle is the transmission mount.  they don't match.
is there a kit, or different transmission, or some other thing i must do to make it work?
 thanks in advance.
  Til next time...  HAHAM
Reply #1January 06, 2010, 06:21:15 pm
Re: Transmission Mount switch
« Reply #1 on: January 06, 2010, 06:21:15 pm »
This has some info about that, http://www.brokevw.com/020mount.html
That guys site is full of good info and stuff!
Reply #2January 06, 2010, 07:19:25 pm
« Reply #2 on: January 06, 2010, 07:19:25 pm »
You need to take the brackets off of the Golf transmission and put it onto the Jetta transmission. However, you would be wise to check the codes out at www.scirocco.org/gears to see which one will actually be better.
I don't know how familiar you are with mk1 Jettas but that thing is probably a mini goldmine to the right people.
