Author Topic: What pistons and shafts will fit to 1Z  (Read 4273 times)
January 06, 2010, 08:10:15 am
cardiag
  • 1
« on: January 06, 2010, 08:10:15 am »
Now i have 180hp / 400Nm at wheels but i need more power.
What pistons from PD engine i can fit and what crank/cam shafts ? I need trusted info what parts can fit from PD engine or some other .
Thanks
Reply #1January 06, 2010, 10:42:54 am
rallydiesel
  • 1880
Re: What pistons and shafts will fit to 1Z
« Reply #1 on: January 06, 2010, 10:42:54 am »
No pd crank or camshafts will fit. The pd crank has an oil gear and the 1z block has an intermediate shaft driven oil pump. The pd camshafts can only fit a pd car as they have the injector lobes. I'm not sure about the pistons. Most people put ALH pistons on the 1Z as they are a bit more heavy duty. I think you would need pd connecting rods if you used the pd pistons because I believe the wrist pin recess in the piston is narrower.
You could try the AAZ camshaft. I think it has a bit more duration then the 1Z cam.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2January 06, 2010, 11:51:10 am
blackdogvan
  • 574
« Reply #2 on: January 06, 2010, 11:51:10 am »
You got to 180hp so i can't imagine I can really be of much help but...
http://www.vwdiesel.net/forum/index.php?topic=22587.0
http://www.intengineering.com/VW/Rods/Integrated-Engineering-p7564406.html
And go for a truckinwagon girdle.
1991 Vanagon 1.9 mTDI
Reply #3January 09, 2010, 05:39:29 pm
oldskool rich
  • 446
« Reply #3 on: January 09, 2010, 05:39:29 pm »
i used a 130 PD crank, pistons and rods in my 1Z but theres alot of work involved and i wouldnt do it again if i knew how hard it would be
ALH pistons are the best you can get that will be a direct replacment, i rekon there as good as PD, they certainly look the same. i would say stock pistons and rods will see you just over 200 BHP. AAZ cam does make a difference too
f6squared I.D.S.T
