Author Topic: WTB: Parts for European B3 AAZ  (Read 4974 times)
January 03, 2010, 08:48:10 pm
Big Daddy Roth
  • 298
« on: January 03, 2010, 08:48:10 pm »
I need:
- Air box
- Vacuum line from pump to booster
- Boost tubing and some other bits for the intercooler (PM me for details)
- Amber side marker lights (the small ones mid-fender)
Please :D
PayPal loaded and ready to go.
« Last Edit: March 28, 2010, 04:31:40 pm by Big Daddy Roth »
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1January 04, 2010, 08:54:36 am
GEE-BEE
  • 1604
Re: WTB: Parts for B3 AAZ
« Reply #1 on: January 04, 2010, 08:54:36 am »
 AIR BOXES
Ebay germany
AIRBOX 350160132282
EBAY U.K.
320429992878
GB
I DID SEE A FEW NEW VAC LINES , BUY I CANT FIND THEM NOW..
« Last Edit: January 04, 2010, 11:02:10 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 28, 2010, 07:56:14 pm
Big Daddy Roth
  • 298
« Reply #2 on: January 28, 2010, 07:56:14 pm »
Bump
1993 TD B3 Sedan
Reply #3January 30, 2010, 01:05:48 pm
Big Daddy Roth
  • 298
« Reply #3 on: January 30, 2010, 01:05:48 pm »
A P/S hard line from a VR6 auto passat is a close enough replacement.
So not looking for that anymore
1993 TD B3 Sedan
Reply #4February 15, 2010, 10:16:10 pm
Big Daddy Roth
  • 298
« Reply #4 on: February 15, 2010, 10:16:10 pm »
bump
also looking for the plastic "Sound Dampening Pan" that goes under the engine.
« Last Edit: February 15, 2010, 10:18:09 pm by Big Daddy Roth »
1993 TD B3 Sedan
Reply #5February 16, 2010, 05:42:42 am
Henchman
  • 183
« Reply #5 on: February 16, 2010, 05:42:42 am »
What's wrong with your speedo?
I should have a vac line from a mk3 aaz, will check today to see if they are the same.
You are not missing anything with not having the engine pan.
Ian
Reply #6March 28, 2010, 04:24:05 pm
Big Daddy Roth
  • 298
Re: WTB: Parts for European B3 AAZ
« Reply #6 on: March 28, 2010, 04:24:05 pm »
bump
1993 TD B3 Sedan
Reply #7March 28, 2010, 05:30:47 pm
CdnVWJunkie
  • 309
« Reply #7 on: March 28, 2010, 05:30:47 pm »
I would imagine it wouldn't require much creativity to get a stock 1Z Passat SMIC and piping to work with your AAZ.
Reply #8March 28, 2010, 05:34:36 pm
Big Daddy Roth
  • 298
« Reply #8 on: March 28, 2010, 05:34:36 pm »
Well I have a syncro intercooler (same P/N as 1.6 TD B3) I just need the tubing from the euro passat with the 1.6TD
1993 TD B3 Sedan
Reply #9April 12, 2010, 09:31:53 pm
Big Daddy Roth
  • 298
« Reply #9 on: April 12, 2010, 09:31:53 pm »
up
1993 TD B3 Sedan
