General Information
Troubleshooting
Timing Belt
Topic: Timing Belt (Read 4498 times)
January 02, 2010, 03:12:40 pm
ffgb
Timing Belt
January 02, 2010, 03:12:40 pm »
I am having a hard time trying to remove the timing belt tensioner on my 1984 rabbit 1.6na. The tensioner will not come off of the stud that it bolts too. The stud is too long and the tensioner hits the motor mount on the frame rail when trying to remove it. Does anyone have this problem like me, and how did you fix the problem.
Thank you
January 02, 2010, 04:23:32 pm
FineFrank
Re: Timing Belt
January 02, 2010, 04:23:32 pm »
Jack up the engine with a floor jack just enough to gain clearance. Check your pass side engine mount- it may be shot.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants" -Albert Camus-
January 02, 2010, 04:29:44 pm
Possum79
Re: Timing Belt
January 02, 2010, 04:29:44 pm »
I just took the passenger side mount bolt out and used the floor Jack to raise it up. Worked well be careful nOt to break anything with the Jack
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
January 02, 2010, 04:43:26 pm
Re: Timing Belt
January 02, 2010, 04:43:26 pm »
I've heard others say they just double-nutted the stud and unscrewed the entire stud, rather than trying to remove the tensioner from the stud. Thankfully there's plenty of room on my car!
January 02, 2010, 06:03:21 pm
ffgb
Re: Timing Belt
January 02, 2010, 06:03:21 pm »
Thank everyone for the input. I especially like the one where you double not the stud and back it out. That way of doing it seems much easier then using the floor jack method. Thank you, I'll try that method!
January 02, 2010, 11:32:24 pm
rabbitman
Re: Timing Belt
January 02, 2010, 11:32:24 pm »
I've pulled the tensioner off as far as it'll go and then grab the unthreaded part of the stud and unscrew it.
Then put the new tensioner on the stud and put the stud back in the head.
General Information
Troubleshooting
Timing Belt
