TDI Engine -General Info
2000 Engine Whine
Topic: 2000 Engine Whine (Read 3225 times)
December 30, 2009, 12:11:51 pm
dieselherb1
2000 Engine Whine
December 30, 2009, 12:11:51 pm »
Sounds like its an electric car. Engine from a under hood fire(150-170,000 miles) inj pump from 245,000 mile engine(TB broke) Replaced belt,tensioner and top roller.Your thoughts?
Thanks
January 01, 2010, 01:43:32 pm
Re: 2000 Engine Whine
January 01, 2010, 01:43:32 pm »
a belt is on too tight. if its the timing belt, you'll wear out the IP bushing and need to get it replaced again.
January 03, 2010, 11:35:25 am
diesel smoke
January 03, 2010, 11:35:25 am »
What about the other small roller, the large roller, and the water pump? Those need to be replaced as well when you do a TB job.
'99.5 Bora TD
I
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
2000 Engine Whine
