Author Topic: NA10X injectors in 91 Jetta?  (Read 6408 times)
December 22, 2009, 12:33:54 pm
motomike33y
  • 190
« on: December 22, 2009, 12:33:54 pm »
Just got hold of some new NA10X injectors.  I believe they were for 1.5 but I want to use them in my 1.6 1991 NA Jetta.  Anything special I need to do?  Different pop pressure?  timing?  thanks if anyone knows.
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1December 23, 2009, 07:57:56 am
Re: NA10X injectors in 91 Jetta?
« Reply #1 on: December 23, 2009, 07:57:56 am »
I think but am not sure that the 1.5 had a higher pop pressure, but I think you can use those nozzles as they should be the same. As long as you set it to 155bar I would think it should be fine. I am sure andrew or saurkraut or someone on here will have a difinative answer.
Reply #2December 23, 2009, 12:38:31 pm
motomike33y
  • 190
« Reply #2 on: December 23, 2009, 12:38:31 pm »
I thought it was supposed to be 130 or 135 BAR for the non-turbo, normal aspirated like mine?  I've never checked them, but am contemplating building or buying a pop tester to check all my old injectors.
2012 golf tdi
Reply #3December 23, 2009, 07:45:40 pm
« Reply #3 on: December 23, 2009, 07:45:40 pm »
This is something I have only read about so take it as such.
I thought the 1.5 early pumps were a little different and the injectors opened at 170-180 bar? Maybe I am off on that. I know the 1.6 turbos were 155 and the n/a s are 130. I think that they all took the same nozzles so as long as the breaking pressures are correct for your engine you should be fine.
I thought the 91 was an eco. Eco had a turbo just not a true turbo pump. I don't know what the eco had for injectors though.
Reply #4December 23, 2009, 08:27:54 pm
wolf_walker
  • 1205
« Reply #4 on: December 23, 2009, 08:27:54 pm »
And let's not forget that Bosch lists TWO different numbers for NA 1.6L VW diesels. :)
I haven't been able to stay on hold long enough on the Bosch tech line to ask them why.
I put A2 injectors in my A2 motor/A1 pump caddy, wrong, right?  Nobody knows.
But I'd like to.
Mentat Text Two
Reply #5December 27, 2009, 05:05:12 pm
motomike33y
  • 190
« Reply #5 on: December 27, 2009, 05:05:12 pm »
I've got an older pump off a rabbit, because it would work and the 91 stock pump wouldn't.  I have'nt checked the pump timing, but probably next weekend will have some time, then I'll put it together with the 10x injectors and we'll see what happens.  starter doesn't spin it like I'd like, but we'll see.
2012 golf tdi
Reply #6December 29, 2009, 01:02:33 pm
« Reply #6 on: December 29, 2009, 01:02:33 pm »
the injectors should have a number on the side somewhere "xxx bar". if they havent already been rebuilt and are in the right bodies, that will tell you more about what to time them at.
Reply #7December 29, 2009, 02:59:33 pm
dennis
  • 311
« Reply #7 on: December 29, 2009, 02:59:33 pm »
NA10X injectors fit 1.5 VW, and 2.4 VW in a Volvo.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #8December 30, 2009, 09:55:18 am
motomike33y
  • 190
« Reply #8 on: December 30, 2009, 09:55:18 am »
just got them off ebay-they are remanufactured by bosch-say NA10X.  Also some remanufactured that say NA11X.  will try to pop test them if I can rig up an adaptor.
2012 golf tdi
Reply #9December 30, 2009, 12:10:18 pm
dennis
  • 311
« Reply #9 on: December 30, 2009, 12:10:18 pm »
NA11X = 1.6 Turbo 85ish.
Reply #10January 03, 2010, 04:33:05 pm
motomike33y
  • 190
« Reply #10 on: January 03, 2010, 04:33:05 pm »
NA10X pop tested at around 2100 psi, the NA11X at around 2300 psi.  the injectors I took out popped between 1900 and 2000(the two that worked, the other two dribbled too much to get pressure up to pop).  I'm still trying to get my dial gauge working right to set the injection pump timing, but I'll shoot for about .95 mm and go with the NA10X injectors and see what happens.
2012 golf tdi
Reply #11January 07, 2010, 04:14:15 pm
motomike33y
  • 190
« Reply #11 on: January 07, 2010, 04:14:15 pm »
turned out there were only 2 NA10X, rest were 11X, so I'm going to see about opening up a couple a shimming them down-hopefully this weekend
2012 golf tdi
Reply #12January 08, 2010, 06:05:57 am
dennis
  • 311
« Reply #12 on: January 08, 2010, 06:05:57 am »
I am currently negotiating a 2.4 Turbo DIesel for my Volvo 240 Wagon. The current NA 2.4 uses NA 10X injectors, so I thought I would look up the 2.4 turbo injectors. NA40X. Never seen these before. FIgured they would be NA11Xs.
Reply #13January 08, 2010, 04:59:52 pm
wolf_walker
  • 1205
« Reply #13 on: January 08, 2010, 04:59:52 pm »
That's 144 and 158 BAR respectively, aren't the NA's supposed to be 130 or 135 BAR?
I'm sure it'll run but it has to be screwing with the timing.
Mentat Text Two
Reply #14January 10, 2010, 04:36:14 pm
motomike33y
  • 190
« Reply #14 on: January 10, 2010, 04:36:14 pm »
My Bentley's says the ME engine injectors should be between 130 and 138 bar.  what's the conversion between bar and psi?  I've never had to deal with it before I started playing with these injectors.  Maybe I can detune the NA11X injectors with different washers-since I have several that are too high a pop pressure for my use. any idea what the timing problems would be with the higher pop pressure?  Would car even start/run?  it's been too cold to do much outside where the car sits so I'm brainstorming ideas.
2012 golf tdi
