Author Topic: upper radiator hose  (Read 1966 times)
December 20, 2009, 08:58:34 pm
sdwarf36
  • 159
upper radiator hose
« on: December 20, 2009, 08:58:34 pm »
The car is a 91 Jetta non turbo. PS-AC. I put a radiator in it today-unforuntatly I didnt notice when i got it that the upper outlet pointed a slightly different direction that the original. It points straight at the altenator-outlet is about 2" away. The original upper hose looped around the altenator to the left and has a small hose running to the overflow tank. I had to do some cutting + splicing to get the car going on a Sunday -the hose now goes to the right (as you looking at the front) to the outlet on the block.
 My question is: Is there an upper hose off something that kinda does this? I dont need the grafted in little hose-there is a barb on the radiator i can go direct to the overflow.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #1December 21, 2009, 12:52:52 am
GEE-BEE
  • 1604
Re: upper radiator hose
« Reply #1 on: December 21, 2009, 12:52:52 am »
There are two different hoses , for two different radiators
a/c
non a/c
The a/c type usally have a bend so the compressor doesnt get in the way ?
Hope this help's
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
